04-25-2012, 06:15 AM   #1
What is a SDM failure like?
How does an SDM failure progress? Is it gradual or all at once?
Is it repairable / economically?
Are certain lenses more prone to this failure than others?
Thanks
04-25-2012, 06:51 AM   #2
Anvh's Avatar
Never had failure so don't know.
for lenses.
almost no failures = DA*55, DA*200, DA*300, DA*60-250
more failures = DA17-70, DA*16-50, DA*50-135
04-25-2012, 07:08 AM   #3
joe.penn's Avatar
QuoteOriginally posted by slackercruster Quote
It is like a crushing blow to your moral, the feeling of losing a friend, the "WHHHHHHYYYYYYYYYYYYYYYYYY oh WHHHHHHHHHHHHHHHYYYYYYYYYYYY" [as you are screaming in vain]...
04-25-2012, 10:24 AM   #4
It's happened with every SDM lens that I've owned.....But I still LOVE THE LENSES!!! Mine have started by squeaking. The last culprit, was the DA*60-250- I noticed that it was squeaking more than usual at the last soccer match I was at. I just talked to Pentax Canada, and they suggested I send the lens in sooner than later. So, once again, my lens is adrift in repair land. On my 16-50, it started with occasional squeaks, then intermittently focusing, then not focusing. Ditto for the 50-135. Something makes me think that the ultra dry Okanagan weather effects these lenses. But you know what? I tried other lenses, and I go right back to the Pentax. In my opinion, nothing compares.
04-25-2012, 11:31 AM   #5
liukaitc's Avatar
for my 16-50. It is gradual. I find it became more and more frequent to not focus. and eventually I sent out for repair.
04-25-2012, 11:48 AM   #6
jpzk's Avatar
I had one instance of failure of the SDM and it was a DA*16-50: started with a squeaking, like some of the owners above, and it gradually started to not focus at all in AF.
I sent the lens back and it was returned .... as a brand new copy!
Mind you, it was still under warranty.
JP
04-25-2012, 01:18 PM   #7
Anvh's Avatar
Those that go slowly can often be repaired by yourself by tightening a screw or shaft.
failure, k-mount, pentax lens, sdm, sdm failure, slr lens
Another SDM Failure - 16-50mm f/2.8 Donkeypunch Pentax SLR Lens Discussion 40 12-05-2011 05:09 PM
Beginnings of SDM failure? krypticide Pentax SLR Lens Discussion 11 08-01-2011 11:35 AM
Is this Pentax way of admitting SDM was a failure? mfdesalas Pentax SLR Lens Discussion 49 12-28-2010 11:34 PM
The official SDM AF Failure Thread Donkeypunch Pentax SLR Lens Discussion 43 07-16-2010 04:48 PM
Second SDM failure for DA*16-50mm lens candgpics Pentax SLR Lens Discussion 19 07-07-2010 04:16 AM
All times are GMT -7. The time now is 11:40 PM. | See also: NikonForums.com, part of our network of photo forums!
