04-26-2012, 07:00 AM   #1
DA*55 f/1.4 and 49mm filters
Does anyone know if this vignettes wide-open with a step-down ring and 49mm filters?
04-27-2012, 05:38 AM   #2
steve1307's Avatar
No one is answering?
Well I don't have a DA*55 or a step down ring so I cant replicate the test.
The closest I can do is to get my Revuenon 55/1.2 (which also has 58mm filter) and stop it to f1.4. There's no notch at f 1.4 so i just stuck it in the middle between f1.2 and f2 about where f 1.4 would be,
Next I screwed a 49mm UV onto a 49-58mm step UP ring and then hold it backwards to the barrel of the lens.
Does it vignette?
The answer for my Revuenon 55mm f1.4-ish with reversed step up (or down) ring handheld filter is ........drumroll........Yes, a little bit. You can't actually see the filter ring of course but there is a noticable difference in light falloff in the corners to f1.4 with and without a filter.
Some slight vigenetting is noticealble with the lens at f1.4 anyway but with the 49mm filter it is more than double that.
So.... will the DA*55 vignette at f1.4 with a 58-49mm step down ring and a 49mm filter?
Yes ...a little bit.....maybe......i don't know
I dont know if that was helpful at all?
04-27-2012, 08:18 AM   #3
creampuff's Avatar
Why would anyone be silly enough to step down a lens that uses 58mm filter thread to use 49mm filters?
04-27-2012, 06:33 PM   #4
The reason is obvious and it's a consideration when I buy lenses. Only 49 + 52mm lenses since I have filters for those.
But when you own $600+ lenses it shouldn't be too difficult to come up with the extra money to buy a 58mm or a square filter set for it. This is the digital age and there are very few filters that you actually need imo. A CIRPOL and a 3 stop ND fill almost all of my needs. Maybe a protective filter for special situations (salt spray for example) or a 10 stop ND. I do want to get a square filter set so I can have a grad ND filter though.
49mm, da*55 f/1.4, filters, k-mount, pentax lens, slr lens
Longest Lens that can take 49mm Filters? chickenandavocado Pentax SLR Lens Discussion 21 05-06-2012 03:28 AM
For Sale - Sold: K-7/K-5 battery and charger, 49mm filters, Films zhuxyg Sold Items 2 09-18-2011 04:11 PM
For Sale - Sold: Macro filters 49mm set (Worldwide) slawek Sold Items 5 12-30-2010 09:06 AM
Asahi Pentax 49mm Filters Peqpete Pentax Camera and Field Accessories 2 08-21-2010 04:19 PM
All times are GMT -7. The time now is 04:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
