04-26-2012, 07:20 PM   #1
cali92rs's Avatar
Hard Stop at infinity
Just curious, why don't most modern lenses have a hard stop at infinity? I think its a handy feature. And this isn't pentax specific, I noticed it with my newer Nikon lenses as well.
04-26-2012, 07:31 PM   #2
Do you mean why do they focus past infinity? From what I have been led to believe, plastic auto focus lenses are much more susceptible to temperature. If you calibrate it to stop at infinity at a particular temperature, you might loose infinity at another temperature. I'm guessing many do not have the precision tolerances that some of those good old all metal lenses had. If it's a little out of spec in an opposite direction of what your camera is you might also loose infinity focus too. Another reason is to allow infinity focus of infra red light. You have to focus a bit past infinity for visible light to get infinity focus when shooting infra red.
04-26-2012, 07:32 PM   #3
mattt's Avatar
I'm no expert but how about adjustment of AF?
I just picked up F28/2.8 that would not lock focus at infinity. I had to fine adjust +6 to get it to focus confirm.
04-26-2012, 08:01 PM   #4
joe.penn's Avatar
AF lenses focus past infinity simply because "They Have To" in order to get a focus [for multiple points] [and also for the "Trap" that is required for focusing] - without this there could be no multi-point focusing and thus the only auto focusing you could ever have would be single point focusing. This really does not have much to do with infinity but in order to focus the AF system needs to key it at contrast then past contrast to know to bump it back. Of course this isn't the correct way to explain it but should give you a little more insight into the AF engineering...
04-26-2012, 10:17 PM   #5
From the manual for the FA*600/4
"The distance scale on the lens stops slightly past the infinity mark. This allows the lens to focus on a point past the infinity scale in the case where a temperature change causes the focusing point to shift. Even when shooting at infinity confirm that proper focus is achieved through the viewfinder before releasing the shutter."
From the Pentax 67 Interchangeable Lenses Operating Manual
"Note on Infinity Indication: With a powerful telephoto lens, there may be a focus shift between the distance indicated on the lens and the actual camera to subject distance, influenced by temperature conditions. For this reason, the focusing ring is specially designed to rotate slightly past the infinity indication. So, even when you take pictures at infinity, be sure to confirm good focus through the viewfinder."
04-27-2012, 06:47 AM - 1 Like   #6
crewl1's Avatar
I don't know but it sounds like a great title for a book.
04-27-2012, 02:53 PM   #7
Good catch...definitely a best seller!
04-27-2012, 03:44 PM   #8
cali92rs's Avatar
Ah...that's why I like this place, I learn something new everyday
infinity, k-mount, lenses, pentax lens, slr lens
Would appreciate your help. K-x has hard time focusing at infinity noaslplease Troubleshooting and Beginner Help 1 08-13-2011 05:58 PM
Misc When i say stop it means stop ! deadprez Post Your Photos! 3 08-02-2011 07:38 AM
What does focus to infinity mean? justtakingpics Troubleshooting and Beginner Help 6 04-04-2011 01:04 PM
Any Hard Body Holsters out there (Think Tank? Lowe? anything hard?) cadmus Pentax Camera and Field Accessories 16 03-05-2011 08:25 PM
Why don't all lenses have infinity exactly on the infinity stop? peterh337 Pentax SLR Lens Discussion 19 01-15-2011 08:53 PM
All times are GMT -7. The time now is 06:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
