04-27-2012, 08:14 AM   #1
A friend gave me a mystery lens
Here's one just like it.
No focusing ring, but there is an upside-down numbered aperture ring.
Bellows lens? Enlarger Lens? What is it's purpose, exactly?
Cheers,
Bobbo :-)
04-27-2012, 08:19 AM   #2
Just a guess, it may be a bellow lens for macro photography only.
NaCl(doubt it would be an enlarger lens in T2 mount)H2O
04-27-2012, 09:23 AM   #3
Digitalis's Avatar
I agree with salt water on this - it is either an enlarger lens or a macro bellows lens. If it is a 100mm~150mm lens then it is probably a macro bellows lens, if it is a 50mm then it is probably an enlarger lens - that focal length has always been popular with 35mm enlargers, Using a 50mm lens on a bellows isn't exactly a bright Idea.
04-27-2012, 09:46 AM   #4
It's 150mm.
04-27-2012, 10:00 AM   #5
G and T's Avatar
Its definately a bellows lens though 150mm is unusual they mostly come as 50mm or 100mm.
Glenn
04-27-2012, 10:19 AM   #6
Lowell Goudge's Avatar
It is definitely a bellows lens, in fact it is very similar to a 135 mm soligor lens I got with my Miranda bellows, except my lens had the aperture mechanism fall apart, and all the blades separate
It can't really be an enlarger lens unless it is for a very large format negative, although the speed is about right
One thing you can do to verify this is to hold it above a piece of paper and focus on something distant. Judge how far above the paper the lens needs to be held to focus, if this is more than 40-50mm then it is meant to have a bellows between it and the camera. Bellows lenses are typically designed so that they can focus from infinity down to 1:1 or better on the bellows
04-27-2012, 10:41 AM   #7
RioRico's Avatar
Usually the upside-down aperture numbers indicate an enlarger lens, but this is for bellows macro. The giveaways are 1) the name MACROtel meaning Telephoto Macro (there is also a Macrobel bellows), and 2) the T2 mount, suitable for bellows of many camera mounts.
The focal length is not significant -- I have Wollensak and Eastman enlarging lenses of 162-182-190mm. These were and are used for enlarging 9x12cm and 4x5in negatives. Focal lengths in the 250mm vicinity are for 5x7in negs. These are not uncommon.
k-mount, lens, pentax lens, slr lens
Have you ever bought a mystery lens? ripit Pentax SLR Lens Discussion 21 04-20-2013 02:15 AM
Mystery Focal 135 f2.8 m42 Lens smurofxatnep Pentax SLR Lens Discussion 10 05-08-2012 02:14 PM
mystery lens ckswong Troubleshooting and Beginner Help 6 04-20-2012 06:36 PM
Ozeck mystery lens Heiberg Pentax SLR Lens Discussion 3 12-23-2010 01:01 PM
Mystery Lens Experiment (warning: lots of photos) hangu Pentax SLR Lens Discussion 52 07-28-2010 09:03 AM
All times are GMT -7. The time now is 04:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
