05-01-2012, 10:01 PM   #16
Laurentiu Cristofor's Avatar
QuoteOriginally posted by twitch Quote
When using the FA31 just get closer, I think it's that simple. I think you are just seeing the ability for longer lenses to create more subject isolation, however the FA31 allows for more intimate photos being a wider focal length.
+1
05-01-2012, 10:30 PM   #17
QuoteOriginally posted by Laurentiu Cristofor Quote
+1
No pixie dust in that pic, I am afraid (to my eyes).
05-02-2012, 12:27 PM   #18
QuoteOriginally posted by chesebert Quote
I'm not surprised - I never saw any pixie dust in any pictures - I have no idea what it is supposed to be - I simply posted this to show that subject isolation is achievable with the FA 31, as twitch had pointed out.
05-02-2012, 12:33 PM   #19
Todd Adamson's Avatar
Everyone's different, and PD is obviously hype/subjective. But when I hear the words, I think of a combination of color, local contrast, and dimensionality which make the image nearly jump off my screen, much like what I see routinely with my Zeiss lenses. And to my eyes, that photo is dripping with it.
05-02-2012, 12:45 PM   #20
Ash
Community Manager
Ash's Avatar
I see the most striking differences between the FA Ltd lenses and others in their respective focal lengths coming from portraiture. The FA Limited club features a lot of such examples.
05-02-2012, 12:51 PM   #21
I think the differences in the FA limiteds have more to do with differences in focal length than with differences in individual rendering. That said, I prefer the DA *55 to the FA 43 -- probably more due to a little longer focal length. The FA 31 is very nice, but obviously produces very different results than, say, the FA 77 will produce.
05-02-2012, 03:37 PM   #22
QuoteOriginally posted by djc737 Quote
I have all three and have come to using the 43 and 77 along with the 15. Very nice trio. I find very little use for my 21 and 31. YMMV.
If I want to use a single prime lens for a day of shooting, I will usually choose the FA31. For a multiple prime lens day, I often choose the same ones as you--DA15, FA43 and FA77, although the 43 would get the most use, by far. I consider myself very fortunate to have the luxury of such fine glass.
Rob
05-02-2012, 04:52 PM   #23
Class A's Avatar
I don't think that is true. They all have different point spread functions, the 77mm and 31mm being closer to each other than the 43mm.
Just look at OOF highlights and you'll notice that the 43mm can feature quite a harsh outer ring with certain shooting parameters, suggesting over-corrected spherical aberration. This results in harsh bokeh. I guess this is why some call the 43mm "temperamental".
I've never seen such harsh bokeh from either the 77mm nor the 31mm, so I'd say that clearly it is not just the focal length that differs between the three amigos.
05-02-2012, 08:22 PM   #24
Sage97's Avatar
I have all three and have come to using the 43 and 77 along with the 15. Very nice trio........
I'm about to have the same trio.
05-02-2012, 08:54 PM   #25
The FA43 can exhibit a somewhat nervous bokeh with a busy background at f1.9. Stopped down to f2.8, it is buttery smooth, and the transition from sharp to unsharp is truly lovely. If this is what temperamental is, then give me a big dose of it. Below is a sample taken at f2.8 with a K-7.
Rob
05-02-2012, 10:00 PM   #26
QuoteOriginally posted by robgo2 Quote
f/2.8 is a great f-stop on APS-C. It blurs the background just enough to create isolation, but not to the point where you cannot recognize the surroundings. And fast lenses are usually at their best in all respects at that setting.
05-02-2012, 10:22 PM   #27
TOUGEFC's Avatar
Rob
Problem with the FA43 stopped down at f/2.8 is if there is any highlights, they get rendered as very ugly octagons, dues to its 8 blade aperture.
05-03-2012, 12:57 AM   #28
If you had to sell either the FA35 or FA31, which would it be, discounting price?
If prices wasn't the factor, FA31 wouldn't be called premium, but yes I will keep FA31 in that case just because it's limited, a bit wider and has better build. Optically, it's fantastic but only as fantastic as FA35.
05-03-2012, 02:04 AM   #29
bickrs's Avatar
QuoteOriginally posted by TOUGEFC Quote
This is probably why my own favourite people shots with this lens are f/2.4 or below, mainly 2.4, unless it's a frame filling portrait, of course.
Back to the trio, I'm similar to Ash, in that my favourite is probably based on the last best shot I took with either of them.
05-03-2012, 07:31 AM   #30
In the photo that I posted above, I do not see any such effect in the highlights on the shirt or the rug. Granted, they are not sparkly bright lights, but they still look very smooth. I have used the FA43 a great deal over the past year, and I have not encountered any unpleasant bokeh at f2.8 and above, including in pictures of running water. Even at f1.9, the background is usually quite acceptable, unless it is very busy.
Rob
corner, dust, fa, k-mount, lens, pentax lens, performance, pixie, slr lens
Dusty Sensor? (K-x) TheJRB Pentax DSLR Discussion 14 10-04-2011 03:41 PM
Dusty or scratched lens? dvest Pentax DSLR Discussion 3 05-23-2011 11:07 PM
Dusty sensor wjt Pentax DSLR Discussion 16 11-01-2010 10:31 AM
a product that is used to change lens in a dusty or damp environment jon pafford Pentax Camera and Field Accessories 17 10-10-2009 11:31 AM
Dusty 50mm lens ?? StevenVH Pentax SLR Lens Discussion 8 08-23-2009 06:14 PM
All times are GMT -7. The time now is 02:51 AM. | See also: NikonForums.com, part of our network of photo forums!
