05-05-2012, 05:16 PM   #1
Yashica and Pentax mounts.
There is a modification for Pentax cameras that allows y/c mount lenses to fit, while still allowing Pentax lens use. Does this mean that Pentax lenses will work on a y/c mount camera? It seems like it would...
05-05-2012, 06:18 PM   #2
boriscleto's Avatar
There are two ways to use a C/Y mount lens on a Pentax. One is to replace the C/Y mount with a K mount. These are sold by Leitax and are designed specifically for Zeiss lenses. The other way is to 'modify' the C/Y mount flags to fit the K mount.
AFAIK there is no way to mount a K mount lens on a C/Y camera.
05-05-2012, 06:23 PM - 1 Like   #3
I think a bit of history here might help..... and I am leaving a lot out here, but here goes.
Asahi bought the name Pentax from Zeiss (Jena - actually there were 2 Zeiss companies but that is a different story). Pentax and Zeiss worked together for a brief time, essentially designing the K mount, and the K28/f2 is the same lens as the famous Zeiss 28/f2 Distagon from Contax. Rumor has it that Pentax was the origin of the Zeiss T* lens coating (from Pentax's SMC coating). For what ever reason, the corroboration fell apart, and Zeiss went into a partnership with Yashica (later Kyocera bought Yashica) to build the Contax camera line. This was a professional line of 35mm SLRs available from 1975 to until 2005 when the Contax line was folded, with the last camera model being the Contax N Digital (the first digital SLR).
The vast majority of the Contax lenses available are in the initial C/Y mount (2 versions the AE followed by the MM). The C/Y mount is very similar to the Pentax K mount that Zeiss helped Pentax develop. Leitax offers new mounts that will convert the Contax lenses to the Pentax K mount. Rico - our resident lens modification expert (with a dremel), shaves the mount flanges so that they fit on the Pentax camera mount. It is destructive, but it creates a lens that will fit on both bodies to a degree. Rico has a number of posts where he explains his technique.....The Contax Zeiss lenses in the C/Y mount are the older version of the current Zeiss Z lens designs, which new are pretty expensive. For the most part the C/Y lenses are about 1/3 to 1/2 the new price. The C/Y lenses can be remounted to a number of other mounts via the Leitax.com. These are all manual lenses. Since the lugs or flanges are thicker on the Contax C/Y mount, utilizing the K lenses, you would probably have some play in the lens when mounted. The registration distance is the same, however I do not know about the diameter, since I have always just swapped the mounts.
k-mount, lenses, pentax, pentax lens, slr lens
Yashica Lens on Pentax DSLR Pentax Bob Troubleshooting and Beginner Help 21 12-15-2015 10:00 PM
Yashica AF 50mm f/1.8 on Pentax K-r 1 Snap Music! Pentax SLR Lens Discussion 4 02-06-2012 08:09 PM
Amazon 1 day lens sale - No Pentax Mounts interested_observer Pentax SLR Lens Discussion 7 12-21-2011 03:15 PM
For Sale - Sold: Pentax ME Super w/ 50mm 1.7, Pentax AF200S, Yashica Electro 35, Canon Canonet, bulbexposure Sold Items 7 02-26-2010 12:02 PM
All times are GMT -7. The time now is 05:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
