05-06-2012, 01:29 PM   #16
LaurenOE's Avatar
Sorry for the condescension!
05-06-2012, 03:24 PM   #17
The following fix may or may not work but it's worth giving it shot. At your local hardware/lumber store you might find "Shimco Shims" or equivalent. It's a rectangular piece of hardwood that's been machined to form a pair of long wedges. Img002 shows the shim is canted only on one side, and img002 shows the two pieces placed together to form parallel surfaces. Take the two shims and insert them in the affected area of the lens mount until the shims are held in snug (img003, 004). While taking acre to keep the shims from slipping out of the lens mount, steadily push the two shims against each other to spread the warped area of the lens mount.
Sand or file a concave arc on the edge of the two shims that will be touching the lens mount to maximize the surface contact between the warped flange and the shims. I haven't tried to fix a lens mount that's as warped as your lens is but I have used these shims to spread apart some third party m42 to K adapters to make them fit better on my K20D.
I hope this helps,
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
05-06-2012, 04:57 PM   #18
Thank you - I will try that and report back. I think I can figure it out from your pictures.
camera, k-mount, lens, pentax lens, slr lens
KA mount lenses won't fully attach on a K-X cbhicks Pentax SLR Lens Discussion 6 03-17-2012 07:51 PM
New Sigma 150mm macro might/will/won't??? come in K-mount robjmitchell Pentax News and Rumors 145 02-18-2012 07:55 AM
Pentax KX won't shoot with 50mm lens nutballa Troubleshooting and Beginner Help 5 03-28-2011 06:35 PM
Pentax 100mm macro lens stopped responding nezih Ask B&H Photo! 6 02-13-2011 04:42 PM
Weird Lens won't mount rdc Pentax SLR Lens Discussion 6 09-26-2007 05:45 PM
All times are GMT -7. The time now is 08:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
