05-06-2012, 04:55 AM   #1
Chaos_Realm's Avatar
FA 77mm backfocus Issue.
OK so I have been "putting up with" my FA 77 ltd being a bit soft wide open, I didn't expect it to be perfect. But I finally bit the bullet and got a Lens calibration system as I had been getting mixed results with print off ones.
So first I will start by showing the typical results I have been getting with 0 focus adjustment on my k-7. So yeh here is a crop of a shot I took a while ago, which is pretty typical when I shoot wide open. And followed by a crop of the lens calibration results with a +10 focus adjustment. As you can see is still back focusing quite significantly. My other lenses are fine (within the cameras AF adjustment range).
This brings me to the question of what can I do to fix it? I shoot this lens wide open most of the time and need to rely on it being accurate.
I have looked into the option of getting into the debug menu and altering the default AF adjustment, but the guy that was giving people the gateway to this seems to have packed up shop after v1.03 firmware update. I don't particularly wish to go back to v1.02 (SDXC support is required)
I have also considered the option of sending my k-7 and lens back to CRKennedy with my a couple of lenses.
Is there anything else that I have yet to consider?
PENTAX K-7  Photo
PENTAX K-7  Photo
05-06-2012, 05:20 AM   #2
Doesn't modset.474 works with 1.03?
05-06-2012, 05:36 AM   #3
I would just return and get another 77 that works with your camera. Or you can always sell and get another, if past exchange period. My 77 is sharp wide open. I also don't believe you can roll back the updates.
05-06-2012, 07:34 AM   #4
QuoteOriginally posted by chesebert Quote
Unfortunately had the lens for over a year (and bought it second hand). I started off thinking that it was just me lacking skill when it came to fast lenses. I then tried testing with the print out alignment systems and had inconclusive results after a 6 months. (I gave up thinking I'll just need to get it right once I get a decent alignment kit.. and well you know the rest of the story.
I don't want to sell this particular lens I would rather send it (and the camera) to get it adjusted by CRKennedy.
Has anyone done this? How long and how much should I be expecting it to cost me?
I was just hoping that there is something that can be done before it gets to that stage.
QuoteOriginally posted by yusuf Quote
As for this I think from general reading it might be possible but I need to be running V1.11 (preferably v1.12) to use SDXC cards. There is no real evidence of it working beyond 1.03 so I am not sure about that method.
05-06-2012, 10:19 AM   #5
QuoteOriginally posted by Chaos_Realm Quote
Why don't you try it with whatever firmware version you are using, shouldn't take more than a few minutes to test, there is no side effect so nothing to lose.
05-06-2012, 06:44 PM   #6
I wasn't overly game on trying this as I had no idea on how it could screw stuff up lol.
I gave It a shot On K-7 firmware V1.12, You need to have the card cover flap thingy open when you turn it on. But I managed to get it sorted.
I am just going to have to wait and see to get my other lenses on to test if it royally screwed their settings :S (Unless it will only adjust for attached lens... but I am assuming not)
05-06-2012, 11:57 PM   #7
selar's Avatar
Took about a month for my DA*16-50/K10D
05-07-2012, 12:02 AM   #8
QuoteOriginally posted by selar Quote
Did they have to send it back to Vietnam for dis-assembly then on to japan to test and fix components, then return to Vietnam for re-assembly? LOL
05-07-2012, 01:32 AM   #9
Send it to Pentax with the body to get it calibrated.
http://jarek.smugmug.com
adjustment, af, calibration, crop, k-7, k-mount, lens, lenses, option, pentax lens, results, slr lens
What causes backfocus or frontfocus? yusuf Pentax SLR Lens Discussion 19 06-08-2012 03:44 PM
Tamron 17-50 2.8 backfocus basikal_kusayang Pentax SLR Lens Discussion 5 04-24-2012 08:17 AM
Backfocus with 645 klaus123 Pentax Medium Format 4 03-25-2012 07:39 AM
SuperProgram backfocus elho_cid Pentax Film SLR Discussion 8 09-17-2011 11:30 AM
K5 front/backfocus - WOW! bpjod Pentax K-5 35 11-16-2010 02:46 PM
All times are GMT -7. The time now is 09:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
