Originally posted by nms_photog For under $100, I'd be all over that Sigma.
Originally posted by newmikey I second that wholeheartedly! I picked up the Tammy so cheap (brandnew) I didn't even notice the money was gone
I barely ever need anything longer than my DA*50-135mm but on the rare occasions I do, it's a lifesaver. The purple stuff is dealt with quite easily by using the Lensfun library in raw conversion and a dedicated purple-defringifier plugin in GIMP.
Now, close-up is a whole different cookie! I do have the Sigma 50mm/f2.8 EX DG Macro and it is absolutely fabulous but forces you to almost physically crawl into whatever you're shooting. The Tammy does well on its 1:2 macro mode and because it's so lightweight, it gets thrown into the bag when I travel. I find the bokeh when in macro mode quite pleasing actually.
The convenience & results of the Tammy are so good, that I also ditched my Vivitar 100/3.5 macro, which was sharper, but less convenient. I also noticed that the Raynox DCR-150 close-up adapter works better with the Tammy than the Pentax 55-300, which would vignette at certain FL's. I think the Tamron's larger diameter helps in this circumstance.
Originally posted by boriscleto Even though it's only 1:3 at 300mm, I don't think the 55-300 has any problems with close-ups.
The 55-300's maximum magnification is actually 1:3.5, it's just not the same as 1:2. While the Pentax does have some advantages over the Tamron - 55mm, far less PF, better color & contrast - the Tammy is at least as sharp (if not sharper) and for my applications, the minimum focus distance being 2/3 that of the Pentax is a huge asset. I'm fortunate enough, though, that if I need to do real long shooting I have the Sigma 170-500.
