Originally posted by Poliyoyo I have a Kx body and a Smc-M 50mm 1.7 and just recently bought a 44M 58mm f2 Helios.
The lens is in great condition and works just fine.
After using the 50mm for a few months in a bokeh frenzy at about 1.7-2.8, i decided to finally compare it's sharpness to my 18-55 kit lens at 50 mm. I noticed it works just fine from F1.7 to about 4, the dof increases and the shutter speed decreases, as they should.
The problem is after F4 in the 50mm M, all the pictures tend to have the same depth of field, nothing comes even close to what the 18-55 at f.5.6 can do.
The same thing goes for the Helios lens too.
The guy i bought the Helios from said he had the same problem with his K10 with manual lens.
Does anybody else here have the same problem?
When you adjust the aperture of the helios past f4, does the viewfinder continue to get darker? If you take it off the camera and do the same thing, does the aperture continue to get smaller?
