Originally posted by rbefly Hello Stupot1, Welcome to the Forum!
I don't have either Vivitar or the Kiron, but I've seen lots of photos, they're all over the web.
However, I've owned my Pentax M 100mm f/4.0 Macro for some time now and have shot hundreds of macro photos with it.
The main difference I see is in the bokeh. There's a reason the Viv S-1 is called the "Bokina". It is absolutely awe-inspiring, the way the lens renders the OOF highlights. "Dreamlike" is the word that comes to mind.
Aside from that, I'd put the M 100mm up against virtually any Macro tele, even ones costing several times more. For sharpness, color fidelity, I.Q. and rendering, it is equal to most good macros, or very nearly so.
Put another way, there's no $100.00 (USD) macro that comes close. If you want to spend more, you'll find an equal. If you spend considerably more, you will be rewarded with somewhat better bokeh.
If you want the convenience of A/F, auto-aperture and perhaps a lighter lens, again it will cost much more. JMO.
Here's a couple examples;
Good luck!
Ron
Isn't the Bokina the Tokina 90 f2.5?
I have the M Macro, and think it is a wonderful lens
