Originally posted by Laurentiu Cristofor Originally posted by RioRico: One kinky trick: Thread a mount-reversal ring onto the front of a prime. Shoot as normal. For close work, just flip the lens over!
I tried this with a 28mm, but focusing range was small and working distance was short too. Plus, it requires removing the lens from the mount, which I avoid to do outdoors.
Yes, 28mm is too short, and the trick sucks amid dusty environments. But it's cheap!
Any prime reversal trick requires shooting at the PK register distance of ~4.5cm, too close for much outdoor work. Zooms are another matter. The A35-80/4-5.6 trick I mentioned has a wide range of working distances. I'm testing it right now with a 49mm-PK mount reversal ring whose base is about 4.5mm thick. I'm measuring CFD (close focus distance) from the lens front, and the magnification:
* At 35mm: CFD= ~6cm, M= ~2:1
* At 80mm: CFD= ~17cm, M= ~1:2.5
And it reaches infinity focus at around 75mm. The lens is rotten when used normally, but decent when reversed. A nifty fifteen-bucks macro solution, eh?
These numbers are ONLY for this lens with this adapter. Similar M- or A-type cheap midrange zooms will give different results. A 28-70 or 35-70 likely won't reach infinity focus. A 28-90 will likely go 'way beyond infinity, as well as having a longer CFD and less magnification at 90mm, but I'm too lazy to test that right now.
Or am I? Aww, what the hell, let's see what happens! I'll put my Quantaray (Sigma) 28-90/3.5-5.6 onto a 55mm-PK mount-reversal ring with a base about 2mm thick.
* At 28mm: CFD= ~5cm, M= ~2.5:1
* At 90mm: CFD= ~28cm, M= ~1:4
And it also reaches infinity focus at around 75mm. The Quantaray is rather better than the A35-80 when used normally, but it's still no prize-winner. I'll leave testing of 70mm zooms to someone else. Any volunteers?
So, here's a kewl way to repurpose those cheap midrange zooms with aperture rings: flip'em!
