I cannot personally judge any of the other lenses, but I have owned a Sigma OS for several months now (first Nikon, now Pentax) and it is a very impressive lens. Its only weakness is at 200 mm wide open, where it is a little soft (sharp enough for normal screen/print sizes, but no so much at the pixel level); anything else is sharp (as in "pixel-peep-sharp"), and between f/4 and f/8, very sharp (as in: you could use near 100 % crops as your final photo). Then again, from what I've seen on the web, you will need to look closely to see the advantage over the Tammy.
I would definitely recommend getting a lens with an integrated optical stabilizer. Having the picture stabilized in the viewfinder can be a huge help with accurate framing. Also, at least the Sigma's OS is just a tad more reliable at very slow shutter speeds than the K-5's shake reduction system. When comparing I found that both are quite capable down to about 1/20 s at 200 mm with medium focus distances (and solid shooting technique), but the keeper rate with Sigma's OS is noticably higher.
