05-16-2012, 08:32 AM   #1
Zephries's Avatar
What is the difference between KA and K mount?
Hello,
I recently bought a K-5 and and buying some old lenses, but I am new to photography and don't really know what I am doing yet. I am looking on ebay for some lenses and I came across a KA mount lens and am wondering if it is a K mount type.
05-16-2012, 08:49 AM   #2
this site explains it perfectly Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
bottom line ka means the automatic aperture setting with manual focus and k is both manual focus and manual aperture setting
05-16-2012, 08:50 AM   #3
Ole
Ole's Avatar
The KA mount is the second generation of the K mount and allows for the camera to set the aperture. A lens with a KA mount is preferable over a plain K mount because it makes all exposure modes of your K-5 work as was the lens a modern DA lens. You just need to always have the aperture ring on the lens set to the "A" position.
05-16-2012, 08:53 AM   #4
jatrax's Avatar
QuoteOriginally posted by pearsaab Quote
Correct except it assumes that ebay sellers have a clue about what they are selling. Some do, some do not. Be very careful buying anything on ebay if you do not know what it is. Do not assume the seller knows. Ask here if you need help, someone can usually tell you what you need to know.
I have seen sellers use PK, PKA, K, KA all interchangeably because they do not understand the sometimes subtle differences.
05-16-2012, 08:58 AM   #5
Zephries's Avatar
The page that was recommeded is very good, but the K and KA mounts are categorized differently. So will a KA mount fit the K-5?
05-16-2012, 09:04 AM   #6
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
QuoteOriginally posted by Zephries Quote
Yes, ever lens made by Pentax and for Pentax cameras will fit your K-5. Some need an adapter for using screwmount lenses. But the bottom line is, they all work.
05-16-2012, 09:10 AM   #7
RioRico's Avatar
QuoteOriginally posted by photolady Quote
Also, there are two types to be wary of. Some Vivitar (mostly) lenses have an oversized aperture linkage shield which prevent mounting the lens. Some Ricoh (mostly) KAR lenses have the bothersome "Ricoh pin" that can cause the lens to jam on the camera. Both are easily removed; the lenses are then quite usable.
05-16-2012, 10:22 PM   #8
Marc Sabatella's Avatar
All lenses with the letter "K" in the mount physically fit. The only differences has to do with what sort of automatic features might be available - "A" means autoexposure is supported, "F" means autofocus is supported.
05-16-2012, 10:47 PM   #9
boriscleto's Avatar
You have to be careful of Konica AR mount lenses as well. Sometimes they are listed as KAR or K/AR.
k-mount, ka, lenses, pentax lens, slr lens
Ricoh Rikenon 135mm 1:2,8 (K-mount) vs. Jupiter 37AM 135/3.5 MC (M42 mount) vlazduhu Pentax SLR Lens Discussion 23 02-16-2012 12:57 PM
Trade my Contax/Yashica mount 500mm tokina mirror for a K-mount? ChopperCharles Pentax SLR Lens Discussion 2 05-23-2011 02:44 PM
Tamron Adaptall & Adaptall 2 Mount: What's The Difference? minahasa Pentax SLR Lens Discussion 5 04-20-2011 07:26 AM
Difference between SMC 85mm Screwmount & K mount versions jag0 Pentax Film SLR Discussion 7 02-14-2011 09:33 PM
quick adaptall mount difference question tvfd911 Pentax SLR Lens Discussion 4 12-21-2009 01:29 PM
All times are GMT -7. The time now is 06:15 AM. | See also: NikonForums.com, part of our network of photo forums!
