01-18-2008, 12:16 PM   #1
Finn's Avatar
Cap for B+W lens hood?
I recently picked up this B+W screw-in lens hood:
B+W | 49mm Screw-In Metal Wide Angle Lens Hood #970 | 65069645
I can't put on the lens' regular snap-on lens cap anymore, so I'm trying to find a slip-on lens cap to go over it. By my ruler the outside diameter is 70mm across. Anyone know if this one will work?
B+W | 70mm Push-on Lens Cap | 65014141 | B&H Photo Video
I could just order one and check, but I'm trying to avoid the hassle of having to send it back if it doesn't work.
Anyone? Anyone? Bueller?
01-18-2008, 03:14 PM   #2
creampuff's Avatar
Have you tried using a larger diameter clip/pinch on lens cap? The pictured lens hood looks similar to what I have on a few of my lenses and I use the wider lens caps quite easily.
70mm, cap, hood, k-mount, lens, pentax lens, screw-in, slr lens
Lost lens cap on 18-55mm DA L. Can anyone confirm if this eBay cap is the correct one philthy Pentax SLR Lens Discussion 3 10-15-2009 01:26 AM
Lens cap for the 49mm metal lens hood filmamigo Pentax SLR Lens Discussion 8 03-18-2009 04:15 PM
Where can I find the polarizer cap for DA* 50-135mm lens hood jazzman Pentax SLR Lens Discussion 7 12-11-2008 06:29 AM
All times are GMT -7. The time now is 01:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
