05-21-2012, 04:59 AM   #1
Vivitar 50mm f1.7 won't focus to infinity
I've had a manual Vivitar 50mm for a while now, and while shooting the other day i noticed I can't focus to infinity. I've tried on three different bodies with the same results. How do i go about adjusting the stops so I can focus correctly? Thanks.
Charles.
05-21-2012, 08:29 AM   #2
Otis Memorial Pentaxian
Every lens is different, but many allow adjustment of the infinity focus stop via set screws. These are usually on the focus ring and often under the rubber grip. Take care if lifting the grip, they tear easily.
05-21-2012, 12:47 PM   #3
On this lens the screws were on the inside. I had to remove the ring around the front element, then four screws to remove the bezel, then there were three screws I loosened, but didn't remove. I rotated it ever so slightly, tested a bajillion times, then finally screwed it all back together. Works now! I figured... it's a $15 lens, what does it matter if I take it apart and break it?
Charles.
50mm, focus, infinity, k-mount, pentax lens, slr lens, vivitar, vivitar 50mm f1.7
Asahi Super-Takumar 1:1.8/55mm Lens won't focus to infinity bingostew Pentax SLR Lens Discussion 15 10-25-2012 08:19 AM
DA 50-200mm Won't Focus Infinity Tobman Pentax SLR Lens Discussion 6 12-20-2011 10:39 PM
Zoom lens won't focus to infinity - ideas? GibbyTheMole Pentax SLR Lens Discussion 5 10-22-2011 07:56 AM
A 50mm /1.2 won't focus to infinity RXrenesis8 Troubleshooting and Beginner Help 46 07-22-2011 10:11 AM
zentar 16 won't infinity focus?? milapse Pentax SLR Lens Discussion 5 09-26-2008 09:45 AM
All times are GMT -7. The time now is 12:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
