05-24-2012, 08:59 AM   #1
Insanely humble
savoche's Avatar
D FA 100mm Macro WR jerky focusing ring
Hi all,
I just received my DFA 100mm Macro WR. I noticed right away that the focusing ring is far from smooth. Being a Quick Shift it should be smooth even in AF-mode, but it is never smooth, not in MF, not when off the camera. It feels a bit like when turning a set of small cog wheels that are not toothed right - uneven resistance, but with the same unevenness for each revolution (if that makes any sense). Twisting the focus all the way from close to far gives me 10 "periods" of jerky resistance, not very strong, but sufficient to make precise focusing difficult.
Just as a comparison, my non-quick shift Sigma gives more resistance, but also more even, if the camera is in AF-mode. And even the kit lens (w/quick shift) is *far* more smooth than this DFA. The 15 Ltd is in another league entirely.
I suppose the only thing to do is to return it...
05-24-2012, 09:19 AM   #2
I think you just answered your own question. Good luck.
05-24-2012, 09:21 AM   #3
crewl1's Avatar
Yes that does not seem correct.
I do not notice any variance in resistance with my DFA100WR and most of my macro focus is done manually.
Return for a replacement.
05-24-2012, 09:43 AM   #4
jatrax's Avatar
Not good, mine is silky smooth all through the focus throw.
05-24-2012, 10:16 AM   #5
Insanely humble
savoche's Avatar
Yes, will definitely return it. It's the first defective lens I've had, and it put me a bit off - have to let my disappointment level sink a bit before returning it, or else I won't want a new one
It is quite prone to CA wide open, but *very* sharp. And anyway, there is nothing wrong with the 15 Ltd I got in the same shipment - smooth as silk, sharp as a razor (at least in the center!)
05-24-2012, 10:29 AM   #6
crewl1's Avatar
Some have indicated CA in some copies.
My copy happens to have little to no CA problems so your replacement may be better.
05-24-2012, 01:24 PM   #7
Insanely humble
savoche's Avatar
Yes, definitely hope the replacement is better. Although there isn't much left of the CA at 3.2, well, I'd expect there wasn't much at 2.8 either, really.
I'll need to talk to the shop before returning. If they suggest to repair it rather than exchange it, I'll just cancel the deal and look elsewhere.
100mm, 100mm macro wr, camera, dfa, fa 100mm macro, k-mount, macro, pentax lens, resistance, shift, slr lens, wr
100mm f2.8 macro wr not focusing sharp pentaxk10duser Pentax SLR Lens Discussion 5 04-05-2012 03:59 PM
Anybody know off hand how to remove the focusing ring on an A 50mm f/2.8 macro? Steinback Pentax SLR Lens Discussion 3 09-17-2011 07:33 PM
D-FA 100mm macro focus ring sajah Pentax SLR Lens Discussion 4 02-09-2010 09:31 PM
FA 100mm Macro Focus Ring shiner Pentax SLR Lens Discussion 13 03-04-2009 12:50 AM
All times are GMT -7. The time now is 06:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
