Originally posted by RioRico Then yours isn't spinning as far as it should. I'm afraid it means opening the lens for reconstructive surgery. Follow @MegaPower's suggestion. And look for out-of-place bits that may interfere with the focus.
Agree on this, I think I posted earlier that mine was 180 degrees but that was in error, I used a little mark on the ring to track and darned if there are not two such marks. So if you are not getting 240 degrees something is stopping it from rotating fully, which makes the most sense of anything so far.
I have a S-M-C 150mm that came to me with a loose screw stuck in it that prevented the focusing ring from turning fully. I opened it up and the screw dropped out, works fine now. Never did find where the screw was supposed to go. I suspect it was dropped in at the factory and never found.
