05-30-2012, 08:00 AM   #1
Why do they make some Lenses White??
I have noticed alot of Canon lenses and even the upcoming Pentax 560mm is white, who thinks this is a good idea? Most of the time these lenses are used for wildlife where white sticks out like a sore thumb, and you have to cover it up with those camo socks.
05-30-2012, 08:16 AM   #2
GabrielFFontes's Avatar
Also, it gets dirty...
I guess its just to make you pop out in the crowd LOL
Being a human you'll already pop out enough on the wild
05-30-2012, 08:25 AM   #3
photocanadian's Avatar
Location: capital city, the land of eh (Ottawa, Canada)
They sure are pretty ... especially if they say "Pentax"
05-30-2012, 08:42 AM   #4
eddie1960's Avatar
the arguement is White is less sensitive to heat build up.
05-30-2012, 08:47 AM   #5
Julie's Avatar
Probably just to stand out (and make people think that you're a pro shooting with a white Canon L lens )
I personally prefer the black... although silver FA* lenses are pretty and stand out, the silver scratches off really easily. I'm just not a fan of the white.
05-30-2012, 08:49 AM   #6
Julie's Avatar
QuoteOriginally posted by eddie1960 Quote
That's a good point... but it wouldn't want to make me buy a white one even if I were going to spend all day in direct sunlight...
05-30-2012, 08:50 AM   #7
Really if white is less sensitive seems kinda lame.
05-30-2012, 08:54 AM   #8
JinDesu's Avatar
QuoteOriginally posted by coreyhkh Quote
Might be lame, but pretty important on extreme tele lenses. The expansion of lens elements within the lens can throw focus off pretty far. Also, performance issues come into play when you have large lens elements changing size.
05-30-2012, 09:10 AM   #9
Marc Sabatella's Avatar
Right, it's not about photogrpaher comfort, it's image quality - a lighter color lens has the potential to perform better, at least for large telephotos.
05-30-2012, 09:10 AM   #10
Anvh's Avatar
QuoteOriginally posted by JinDesu Quote
Reminds me of the SR-71, when they it's in the hanger and they are fuelling it the need to put buckets under it to collect the fuel that drips out.
The aircrafts heats up in flight and so expands sealing the gaps.
The high temperatures generated during flight required special design and operating techniques. For example, major portions of the skin of the inboard wings were corrugated, not smooth. (Aerodynamicists initially opposed the concept and accused the design engineers of trying to make a Mach-3 variant of the 1920s-era Ford Trimotor, known for its corrugated aluminum skin]) The heat of flight would have caused a smooth skin to split or curl, but the corrugated skin could expand vertically and horizontally. The corrugation also increased longitudinal strength. Similarly, the fuselage panels were manufactured to fit only loosely on the ground. Proper alignment was only achieved when the airframe heated up and expanded several inches. Because of this, and the lack of a fuel sealing system that could handle the thermal expansion of the airframe at extreme temperatures, the aircraft would leak JP-7 jet fuel on the runway. At the beginning of each mission, the aircraft would make a short sprint after takeoff to warm up the airframe, then refuel before heading off to its destination.
05-30-2012, 09:11 AM   #11
JinDesu's Avatar
QuoteOriginally posted by Anvh Quote
That is terrifyingly awesome - I did not know that.
05-30-2012, 09:28 AM   #12
Banned
The first white telephoto lens were manual focus ones; also ones which were more effected in direct sunlight and/or heat - perhaps due to design. Some even featured a beyond infinity range to somewhat compensate for this. But also think about this one; just noting aperature ranges as example only. If the lens is in that much direct sunlight (and even if the subject is in a bit of shade) then one would most always not need a wide open aperature; and one would be able to stop down enough stops to have the depth of field cover any heat issue.
Even if that lens were in fact black and in both extreme sunlight and heat - it would be effected, but not much. BTW I saw this lens, but did not get to shoot through it while in Germany.
05-30-2012, 09:37 AM   #13
From Wikipedia: (SR-71)
05-30-2012, 09:51 AM   #14
Does the sigma 500mm F4.5 have issues with the heat? its black
05-30-2012, 09:56 AM   #15
cali92rs's Avatar
People claim it's due to heat build-up...yet Nikon's exotic telephoto line-up is black, and how many people complain about IQ with those lenses?
k-mount, lenses, pentax lens, slr lens
Does Zeiss still make any lenses in Germany? slackercruster General Talk 5 03-30-2012 02:24 PM
When/what kind of photo would you make it black and white? telly0050 Photographic Technique 18 09-21-2011 01:03 PM
can i make k-x shoot in black/white? hockmasm Pentax DSLR Discussion 8 05-07-2010 11:44 AM
how can you make a photo black and white rustynail925 Digital Processing, Software, and Printing 26 10-15-2009 04:01 PM
At Combo's request Pentax will make a limited white series K-m+kit lens RaduA Pentax News and Rumors 9 12-25-2008 05:14 AM
All times are GMT -7. The time now is 04:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
