Originally posted by theflyingjocksman it sucks that sigma only think about canon or nikon for there high end lenses agreed on the petition
It really is a shame. But, from an objective, economic standpoint, lenses that are so niche as those, I can understand why they would neglect Pentax - a cost-benefit analysis would most likely yield a negative return for Sigma (despite the only change being the mount...). So I don't know...
Originally posted by Bob from Aus My Sigma 500mm and Pentax 60-250 is brilliant. I can always use the sigma 1.4 converter for the extra. At least i can carry my kit in the field.
Can you comment further on how the 500 f/4.5 is? Some questions that I have not been able to answer are:
- Is it weather sealed? I assumed it was since it has the "EX" designation, but I was unable to discern officially.
- How would you rate it as compared to the best lenses Pentax has to offer?
- Is it true that only the Pentax mount has no HSM and is thus given screw drive? If yes, how loud/fast/effective is it on the K-5?
- What do you recommend with regards to tripod/monopod set-up?
Originally posted by littledrawe I would say that one of those lenses should be a prime, especially if you were to have the 300-800mm, but I certainly would not complain if I was forced to use the setup you mention originally!
When lenses are that expensive and specially made, is there really that much of a difference between a prime and a zoom in terms of IQ? For instance, I would consider the DA* 60-250 as one of the sharpest lenses I've ever used (the DFA 100mm Macro not included, but because it's naturally a macro lens). I figured the 300-800 would be better than a 500mm prime because the
negligible loss of IQ is far outweighed by such a flexible (and extensive) zoom range. Is that an incorrect assumption?
-Heie
