06-05-2012, 03:30 PM   #16
pacerr's Avatar
I will aslo look for a hood, as mine came without one but has the bayonet tabs to take a 1/4 turn hood.
I'd suggest a screw-in type hood -- there's no real advantage to using a tulip/bayonet hood for the applications this lens is most useful. You can "adjust" it with gutless filter rings too.
06-05-2012, 05:08 PM   #17
Transit's Avatar
Lovely lens the 90/2.5.
I find the metal takumar 135mm hood is a suitable addition.
Pete
06-06-2012, 09:07 AM   #18
Lowell Goudge's Avatar
whent back to where I bought the lens, and in a scrap bin, they had a straight hood about 60mm deep. The bayonet would fit but not lock into place, Bought it for $1 and at home with a soldering iron, put a bump in three flats that would ride under the bayonet tab, This added enough friction that it no longer just turns off.
06-06-2012, 09:39 AM   #19
Lens Buying Addict
monochrome's Avatar
There is a fitting hood #23FH as well as a dedicated extension tube and the 01F TC. I found all three on eBay over time for next to nothing. The dedicated Extension Tube makes this lens 1:1.
52B Full Specifications
06-06-2012, 09:48 AM   #20
thanks
Don't need a teleconverter, as I have the 01F already. (and 6 or 7 others) It comes as an accessory with many lenses, in my case with my 200-500/5.6. and unless you intend to always shoot the lens at 180 mm (i.e. with the TC) then it is a PITA because you need to remove the mount, and if you are using the KA adapter, the TC does not allow for correct reporting of aperture, and therefore metering and P-TTL flash are off when used on most cameras. I prefer to use my SMC-F 1.7X AF converter and a KA mount if I want a TC on my tamron lenses, because the pentax converter does correct for aperture so metering and P-TTL flash are correct, and i get a fine AF adjustment,
Extension tubes, don't need 'em. I have a full set of M42 plus a 15-30mm M42 focusing helix, and a set of K mount that will get me past 1:1
k-mount, ka, lens, lenses, m42, macro, mounts, pentax lens, portrait, slr lens, tak
[LBA] Oops, I just accidentally bought a lens Erik Pentax SLR Lens Discussion 19 03-10-2011 09:57 AM
Look what I just bought!!!!! Copyright Troubleshooting and Beginner Help 17 09-15-2010 05:26 PM
LBA spillover, I bought Pentax binoculars Aegon Photographic Industry and Professionals 14 05-06-2010 06:05 PM
Please help… I have “LBA-P”… LBA Paranoia!!!!! pHREDD D Pentax SLR Lens Discussion 14 03-13-2010 07:29 AM
just bought bellows, does that count as LBA? Douglas_of_Sweden Photographic Technique 15 05-04-2008 11:43 PM
All times are GMT -7. The time now is 11:56 AM. | See also: NikonForums.com, part of our network of photo forums!
