06-06-2012, 05:21 PM   #1
What kind of lens mount is this?
Is there anybody know what kind of lens mount this? I'm trying to get a lens adapter to M4/3 but I have no idea. There is a letter "MA" on it. Help!
06-06-2012, 05:49 PM   #2
That will make a nice 56mm equivalent on a M4/3 body. Just right for street photography. Channel your inner Carteir-Bresson!
The "MA" would lead me to believe it's a Minolta mount, but I'm not seeing any bayonet indentations. I originally posted (and then edited the message) that I guessed it would be a typical M42, but the silver mounting area looks too broad and I can't even see if there are any threads.
The silver portion at the rear of the lens almost looks as if it were added to the overall construction of the peace. Is it some kind of add-on or adapter?
06-06-2012, 05:59 PM   #3
Arjay Bee's Avatar
Exacta ?
06-06-2012, 06:00 PM   #4
jatrax's Avatar
Probably standard M42 but it could also be T-mount which is M42 x .75 rather than the standard M42 x 1. Just be careful threading it on, if it goes smoothly then you are OK if not do not force it as you will mess up the threads. The fact that the mount area is silver makes me wonder, it looks like different manufacturing than the lens. Also I do not see a auto/manual switch. Which could mean the lens just doesn't have one, or that it is not in view, or that the lens is T-mount not M42.
At any rate what you need is M42 to m4/3 and see if that works. Most likely that is what it is just be careful threading it the first time to be sure.
06-06-2012, 06:38 PM   #5
Hi
The lens is a T2 mount, looks like it could be a M39. Anyways does not matter.
The whole silver assy will come off, don't loosen the screws just twist it off. Then get a T2 mount to m4/3 adapter.
Or if you already have a whatever to M4/3 get a T2 to that mount. They are not hard to find a the T2 mount is used
for telescopes and microscope adapters.
06-06-2012, 10:08 PM   #6
Wow! You guys are AMAZING! That was quick! I really appreciate your kindness! I twisted the silver part and it came off! I didn't know that. Seems like a T2 mount which was what you guys had said. Thanks again!
k-mount, lens, pentax lens, slr lens
What kind of mount is this? Vasyl Troubleshooting and Beginner Help 29 06-02-2012 10:04 AM
what kind of mount is this? Kx-Rick Troubleshooting and Beginner Help 6 08-12-2011 09:42 AM
What kind of lens mount is this wrconley Pentax SLR Lens Discussion 7 11-21-2010 07:36 PM
Need help to identify lens, which kind of mount? cofra Pentax SLR Lens Discussion 2 08-10-2010 03:27 PM
What kind of Vivatar lens is a P/KA mount? Eastern Shore Charlie Pentax SLR Lens Discussion 4 04-17-2007 10:27 PM
All times are GMT -7. The time now is 06:57 PM. | See also: NikonForums.com, part of our network of photo forums!
