Originally posted by calsan Wow, that is phenomenal. I will definitely have to try the stacking format. I don't have photoshop. Do you know of any free alternatives to do this technique?
Originally posted by Marc Sabatella Night doesn't change the basics of focal length. If you want a wide chunk of the sky, you want a wide angle lens. if you want a narrow chunk of the sky - focus on just one constellation, say - you want a telephoto. And if you want individual nebulae and so forth to small/faint to be seen with the naked eye, you need a telescope or similar equipment.
I agree with those who say that assuming you do want wide angle, there is no reason not to simply use the kit lens (unless you want wider still, in which case the Zenitar 16 is probably the only cheap ultra-wide to consider).
Thanks for the advice. I'm still learning about it all and appreciate your words.
Originally posted by mtroute I have done some long exposure work with the Kit 18-55 and have had fantastic results. I think with proper technique you will find it is a great lens for night photography...
These are great. Checked out your EXIF and I will definitely use these settings in the future. Thanks for the comments
