Originally posted by snake Ok, received the lens and it's really in much better condition than advertised.
I mistakenly posted in the stop-down metering thread about the ring issue-
I can 100% confirm that without the detent ball, the ring does drift during the stopdown metering process. It's worst at f2, when it goes to about f2.4-2.8. Later, there's little movement.
I removed the ring, greased it lightly with a sticky grease, which minimized the drift, though there is still a small amount. The detent ball was there, stuck, and nothing behind it, so it just popped off. I removed it and put it in a safe place, but there was nothing there to hold it in place, oddly.
I'm still trying to figure out how and in what mode to use the lens, as it's not as straight forward as it was on my Olympus e510. Simply, one need only look at the EV meter, adjust, then shoot. Here, I don't seem to have that luxury and I get massive overexposure over f2.4 or so.
how are you metering? massive overexposure seems off, I use manual lenses almost exclusively (either m42 or k and m series) and though there is some exposure issues nothing i would define as massive, and mostly using my m42 lenses in manual where i make a small adjustment using =/- ev
you should be able to spin it to where you want camera in m mode and hit the green button and shoot. metering is limited to spot or center no matrix (i use spot mostly)
