06-09-2012, 02:22 AM   #16
Anvh's Avatar
QuoteOriginally posted by newarts Quote
The useful answer is yes. DOF is independent of focal length for macros
The precise answer is...
Focal length always affects DOF due to hyperfocal effects but sometimes not-so-much.
Total DoF = (stuff independent of focal length)/ (1- (distance/hyperfocal.distance)^2)
Hyperfocal distance = F^2/cN where c is circle of confusion & N is f-number
When F increases, Hyperfocal distance increases, therefore the denominator increases, therefore total DoF always decreases with increasing F.
But it is only important when distance is more than about one third of the Hyperfocal.distance.
Dave in Iowa
But not with close up!!!!
Wiki is correct for once.
Depth of field - Wikipedia, the free encyclopedia
This the formula
N = f number
c = circle of confusion
m = magnification
P = pupil magnification
It should be in the books of yours.
06-09-2012, 09:00 AM   #17
QuoteOriginally posted by Anvh Quote
This the formula
N = f number
m = magnification
Can't see the formula. - perhaps you could type it in?
But believe me, there's always a hyperfocal term in the denominator. Its effect may approach zero, as in the close-up case, but it is always there (even if an author chooses to omit it because of its insignificance.)
06-09-2012, 09:43 AM   #18
RioRico's Avatar
His graphic shows:
DOF ~ (2Nc (1 + m/P))/m^2
where m (magnification) is a function of distance and focal length
and p (pupil magnification) is the ratio of exit pupil diameter to the entrance pupil
In other words, we can't just observe the camera setup and plug-in numbers to solve for DOF. This formula also disregards frame size. It is not really usable.
06-09-2012, 12:42 PM   #19
Anvh's Avatar
RioRicco, thanks for that.
If you mean with frame size mean the sensor size then that's covered with the circle of confusion, which in the formula.
And magnification is writing down on the focus indication of most macro lenses so it should be a problem to know the magnification of the lens, pupil magnification is the real problem here since it's not standard given by manufactures.
I'll write an email to pentax to see if they can give me some numbers.
This as for as i know the only way to get accurate DOF calculation with close ups, the other one that Newarts use simply doesn't work in this case. Beside that it doesn't take into account the pupil magnification either which is important with these magnifications.
If Newart doesn't believe me he should look look his formula up and see what it says about this, they should mention it.
You can btw leave "P" out of the formula if you don't use it for close up.
06-09-2012, 01:56 PM   #20
His graphic shows:
The posted equation simply omits the hyperfocal term in the denominator. Note that the "~" means approximately.
The exact equation is:
DOF = 2cN(1+m/p)/m^2/(1-(d/d*)^2) where d* is hyperfocal distance: d*= F^2/cN + F
Furthermore Wikipedia's sentence preceding the approximation says "When s<< H, (nb in my terms d << d*) the second term in the denominator becomes small in comparison with the first...." The preceding equation in Wikipedia is the exact one and reduces to the one I wrote here - including the influence of p.
Dave in Iowa
see http://www.largeformatphotography.info/articles/DoFinDepth.pdf eqn 104
06-09-2012, 02:29 PM   #21
The 'confusion' is based in the 'approximately equals' sign in your equation, Anvh.
06-10-2012, 03:49 AM   #22
Anvh's Avatar
QuoteOriginally posted by ElJamoquio Quote
They also do that with the formula of Newarts so what does that say?
And the PDF that he links with says the error gets larger with magnification...
On page 43 it says you can't use the formula for Macro lenses and since many things aren't known it's the best just to use the manufacture parameters then.
06-10-2012, 10:48 AM   #23
From p.43
When such lenses [nb unsymmetrical lenses] are used at high magnification, the DoF may differ significantly from that given by formulae for symmetrical unit-focusing lenses. In most cases, the parameters required for DoF calculations with such lenses are not known
I agree. But what's that have to do with the existence of a DOF dependence on focal length?
This is a bizzare discussion: I'm demonstrating, based on optics and math, that although a DOF dependence on focal length exists, it becomes vanishingly small at high magnifications.
I'm not sure what Anvh's objecting to.
Perhaps the objection is that I'm unnecessarily nit-picking & showing off by giving a confusing answer to a simple question.
Q. Is DOF at macro scales independent of focal length?
A(1). Yes
A(2). Yes for all practical purposes.
A(3). No but the dependence is insignificant & here's why
I'll choose to explain why whenever possible.
Dave
@Anvh, you say..They also do that with the formula of Newarts - where?
06-10-2012, 11:11 AM   #24
Anvh's Avatar
We are talking about DOF at macro here since that's what this topic is about if you want to discuss something else feel free to start a new topic about it.
Focal length is part of DOF if you want but you can also say that DOF depends on magnification and the aperture, like riorico say magnification is focallength and focus distance but with macro we often talk about magnification and so with 1:1 magnification there is no difference in DOF when pupil magnification and the aperture are the same.
That's why i say that with macro photography DOF is independent from focal length, if you chose to disagree then please do so.
Beside that at 1:1 the focal length difference should be gone right?
About the rest, your first formula simply didn't work for macro and so that's why i commented on it, not sure about your second one, never seen that one before.
Where they do that with your formula, well you commented they use ~ with the formula i quoted but they also use ~ with your formula at Wikipedia.
Anyway all DOF calculation are approximations when look at it, pupil magnification often is not used and non take into account aberrations.
06-10-2012, 12:38 PM   #25
Beside that at 1:1 the focal length difference should be gone right?...
I don't think we disagree - I always have said the effect is insignificant - but that is not quite the same as saying it doesn't exist - an important philosophical/scientific detail.
Like you say, at 1:1 the effect is almost gone. The focal length term in the denominator is
(d/d*)^2 = [(m+1)/(m(f/cN+1))]^2
for a 28mm lens, f:2.8, 1:1 mag, it is about1/10000. A small number indeed! Certainly small enough to ignore - but not zero -
but close enough to zero to completely ignore (only about 1/25 a wavelength of light) - maybe I'll have to change my philosophy on reporting such meaningless detail.
It seems to me that the effect of focal length on DOF is insignificant for magnifications greater than about 1:50. That's a lower mag than I would have guessed.
Dave in Iowa
06-10-2012, 01:23 PM   #26
I'm guessing it's there (I haven't looked) because of the 'thin lens' approximation. But I haven't done any math substantiating or disproving that.... in fact I haven't even looked at any of the equations here, so take my comments with a big grain of salt.
06-10-2012, 01:46 PM   #27
Anvh's Avatar
Actually how did you came with this formula.
It seems to me you simply added the hyperfocal distance and the question is why?
06-10-2012, 01:48 PM   #28
Anvh's Avatar
If you want to have it absolutely precise then you need to take some many things into account that it isn't interesting any more if you ask me
06-10-2012, 04:17 PM   #29
I added it because it should be there.. Here's the detail on how it gets there
The previous equation in the wikipedia article is: first factor fm/Nc out of the denominator, then factor 1/m from the numerator
DOF =2f(1/m+1/p)/(fm/Nc -Nc/fm) = 2f(1/m+1/p)/((fm/Nc)(1-(Nc/fm)^2) = 2cN(1+m/p)/m^2/(1-(Nc/fm)^2)
Using the fact that m= f/(d-f) =(f/d)/(1-f/d), the denominator becomes (1-(Nc/fm)^2) = (1-(Nc/(f(f/(d(1-f/d))))^2) =(1-(d/(f^2/(Nc(1-f/d))))^2)
(1-(d/(f^2/(Nc(1-f/d))))^2) = (1-(d/d*)^2) where d* = f^2/Nc + f - the "hyperfocal distance".
so DOF = 2cN(1+m/p)/(1-(d/d*)^2)
But it is just as useful for macros to leave the denominator in terms of magnification (so you don't have to calculate hyperfocal distance).
DOF = (2cN(1+m/p)/m^2)/(1-(Nc/fm)^2)
Say a focal length effect less than 1% DOF can be ignored, and choose some fairly extreme parameters for normal macro use, like: N < f:22, c~ .02mm, f>10mm, then 1/10 > Nc/fm for m ~ 1/2. That is, focal length effect on macro DOF is less than 1% for magnifications greater than about 1:2.
Dave in Iowa
06-10-2012, 05:37 PM   #30
Anvh's Avatar
Thanks got it, it actually makes sense... XD
100mm, dof, k-mount, pentax lens, slr lens
What Focal Length for first macro?? GDRoth Pentax SLR Lens Discussion 27 08-05-2011 02:53 PM
DOF Scales on DA lenses Capslock118 Troubleshooting and Beginner Help 6 05-03-2011 10:31 PM
Macro focal length for wildflowers kbrede Pentax SLR Lens Discussion 13 04-15-2011 04:52 AM
DOF affected by focal length ? pschlute Pentax SLR Lens Discussion 32 11-25-2009 12:12 AM
Which focal length for a deep DOF in miniatures? Knopfloch Photographic Technique 17 09-18-2009 11:21 AM
All times are GMT -7. The time now is 04:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
