06-08-2012, 05:08 AM   #1
Is DOF at macro scales independent of focal length?
I have a 35 Ltd. and have just take delivery of a DFA 100 WR (yay me!).
More out of interest than anything else, I was wondering whether they had identical DOF at a given magnification. Obviously, at normal distances the 100mm will have shallower DOF than the 35mm for a given aperture. However, at 1:1 the 100mm focuses at 30.3cm while the 35mm focuses at 13.9cm. I was wondering whether the shallower DOF of the increased focal length is exactly matched by the shallower depth due to close focusing.
06-08-2012, 05:18 AM   #2
bdery's Avatar
You would have to calculate it in this particular case. DOf is influenced by distance to subject, aperture and focal length. You can use a website such as DOFmaster to evaluate DOF in your particular case but I'm guessing there will be differences.
06-08-2012, 05:56 AM   #3
As I understand it, DOF is a function of magnification and independent of focal length. So, at the same f-stop and magnification (e.g. 1:1) you should get the same DOF with the DFA 100 WR that you get with your DA 35 Ltd. However, since the working distance will be much different, the rate of falloff of DOF should be greater with the 35. So your background will be blurrier with the 35 than with the 100 (at the same f-stop). On the other hand, the background in the field of view will be wider with the 35.
06-08-2012, 07:15 AM   #4
imtheguy's Avatar
I could wish that TopQuark post a side-by-side sample shot of the view of an object at 1:1 and the background with each lens. That would help some of the slower members (me) understand where the truth lies.
06-08-2012, 07:21 AM   #5
Anvh's Avatar
QuoteOriginally posted by bdphoto Quote
Very correct.
So 1:1 magnification at f/2.8 gives you the same DOF regardless the focal length and distribution of the DOF will also be 1:1, some say the DOF is always 1:2 but that's almost never true.
However... pupil magnification does change the DOF with macro photography so between different macro lenses there will be a difference, so the DA35 and the DFA100 won't give you the same DOF
The 100mm give you more DOF then the DA35.
Sadly i don't know the pupil magnification of either lens so can't calculate it for you.
I could write a mail to Pentax to ask.
Here you have a calculator where you can precisely calculate the DOF.
VWDOF
And here is a read about depth of field and also explain the pupil magnification and his effect.
Depth of field
QuoteOriginally posted by imtheguy Quote
Site above has samples... well calculated samples and diagrams.
06-08-2012, 07:53 AM   #6
Lowell Goudge's Avatar
QuoteOriginally posted by top-quark Quote
I did a study for portrait lenses, using a DOF calculator and considering the magnification of each lens, I have since repeated it for telephoto lenses, with the same result. I have not considered macro, but I expect the results should hold true as well
what i found (to a first order approximation i.e. within less than 10%) was that if you compare any two different focal length lenses, AT THE SAME APERTURE, the depth of field, for a given magnification was constant.
that means at for example F4 on a 50 mm macro at 1:2 magnification, the depth of field would be the same as for a 100mm macro at F4 and also 1:2 magnification but shooting from twice as far away.
06-08-2012, 09:09 AM   #7
RioRico's Avatar
Magnification is a function of distance and focal length, thus DOF depends on focal length, among other factors.
06-08-2012, 09:18 AM   #8
Anvh's Avatar
Depends on which DOF calculator you use, you really need to put in the pupil magnification to get a useful number when working in the macro realm.
example.
Format - 24x36 mm - 24x36 mm
COC - 0.030 mm - 0.030 mm
Focal length - 60 mm - 100 mm
Pupil factor - 1.0 - 0.7
F-number - 8 - 8
Magnification - 1 - 1
------------------output--------------------
Depth of field - 0.960 mm - 1.17 mm
Conclusion, 100mm has more DOF then 60mm lens in this example.
Saying you get less DOF with longer lenses simply isn't correct.
06-08-2012, 09:22 AM   #9
Anvh's Avatar
So if i leave magnification and f-number the same and i change the focal length then the DOF will be different?
06-08-2012, 09:42 AM   #10
RioRico's Avatar
QuoteOriginally posted by Anvh Quote
To keep the same magnification with a different focal length, the focus distance is different. Plug in the numbers and see what happens.
06-08-2012, 09:45 AM   #11
Anvh's Avatar
But if i only change focal length then it would change my magnification and that's what it's all about with Macro photography.
06-08-2012, 10:22 AM   #12
The useful answer is yes. DOF is independent of focal length for macros
The precise answer is...
Focal length always affects DOF due to hyperfocal effects but sometimes not-so-much.
Total DoF = (stuff independent of focal length)/ (1- (distance/hyperfocal.distance)^2)
Hyperfocal distance = F^2/cN where c is circle of confusion & N is f-number
When F increases, Hyperfocal distance increases, therefore the denominator increases, therefore total DoF always decreases with increasing F.
But it is only important when distance is more than about one third of the Hyperfocal.distance.
Dave in Iowa
06-08-2012, 10:22 AM   #13
I agree completely. We can theorize, but there's no substitute for actually going out and putting theory to the test.
These are all photos of the same damned flower, so apologies in advance for the repetition. By the way, if anyone knows what this is I'd be interested to know. They're growing all over my garden (Aylesbury, UK).
First up, 35mm, 1:1, F16
100% crop:
Next up, 100mm, 1:1, F16
100% crop:
If anything, I'd say the 100mm has very slightly deeper DOF, but that's just two pictures. The vagaries of manual focusing are more likely to be the reason for any difference here.
35mm, 1:3, F4
100mm, 1:3, F4
(It had started raining quite heavily when I took this one. Hooray for WR!)
35mm, 1:5, F2.8
100mm, 1:5, F2.8
Hard to say, but I can't see any significant differences in DOF in any of these pictures for a given magnification level and F-stop. Interestingly, taking into account differences in my position and the effect of the wind blowing stuff around the frame, I can't see any significant difference in the AOV either, which is not something I expected. There are slight differences in perspective due to the different working distances, but that is certainly to be expected.
So, the conclusion I'm going to draw here is that if you focus for a given magnification, DOF and AOV are independent of focal length. For macro photography, a difference in focal length would appear only to change the working distance.
06-08-2012, 10:30 AM   #14
Here's such a comparison shot with a cracker box in the background. 50mm lens vs 90mm lens, same DoF, 1:2 mag, focus on silk rose.
Dave in Iowa
06-08-2012, 10:47 PM   #15
Those interested in portraiture should note that the same principle applies to this kind of photography: if you want a head and shoulders shot, DOF is dependent only on aperture. And, assuming you want all your subject's features in focus for this kind of shot, you'll be needing to stop down a fair bit if you're using a fast lens...
100mm, dof, k-mount, pentax lens, slr lens
What Focal Length for first macro?? GDRoth Pentax SLR Lens Discussion 27 08-05-2011 02:53 PM
DOF Scales on DA lenses Capslock118 Troubleshooting and Beginner Help 6 05-03-2011 10:31 PM
Macro focal length for wildflowers kbrede Pentax SLR Lens Discussion 13 04-15-2011 04:52 AM
DOF affected by focal length ? pschlute Pentax SLR Lens Discussion 32 11-25-2009 12:12 AM
Which focal length for a deep DOF in miniatures? Knopfloch Photographic Technique 17 09-18-2009 11:21 AM
All times are GMT -7. The time now is 09:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
