Originally posted by creampuff I was once a dedicated Minolta user once and had an extensive collection of Minolta glass. The MD 45mm f/2 was just mediocre.
I actually like the 45/2 quite a bit. And I suppose to justify this, I should say that I have the 24, 35 1.8, 58 1.2, and 85 1.7. The 45 just has a pleasant charm that I can't resist. And I mean that I find its IQ charming; not just it's size and handling.
Here's a shot with the lens:
Originally posted by iangreenhalgh Hi Jake. I don't get your point, sorry, of course they are different lenses.
My point was that you seemed to suggest that the Canon wouldn't be as good as the other lenses you were listing, and I wanted to chime in and say that I haven't used one, but from the sample photos I've seen users post, it has a lot of character, and high IQ. Character is probably the primary reason I'll buy a lens. Also, you said this:
Originally posted by iangreenhalgh it's a very well built lens too, which I doubt this Canon is
Again, I haven't used the EF 40, but those that have seem to think it's well built.
Originally posted by iangreenhalgh How did you adapt the Minolta? Do you get infinity? If so, is it using a glassed adapter?
I adapted it myself using an m42-EOS mount and an AF confirm chip. I hacksawed the Minolta mount off, preserving the baseplate because the aperture mechanics are attached. I then sanded the mount plate as thin as I could get it. I drilled holes in the m42 adapter to match the minolta screwholes, and sanded it down as thin as I could get it. I then screwed them together, took off the faceplate to adjust for infinity, and bingo.
Here's a shot of the back.
