06-08-2012, 11:31 AM   #1
Unscrewing mount
Hey all, I've got an M35/2.8 with a dirty aperture, so I want to open it up and clean it out. However, the screws that hold the mount seem to be particularly stubborn on this one. I might have already worn them out, but as far as I can see, the screws are mostly wearing out my screwdriver. I'm using a philips head 000 which seems to fit perfectly, but maybe I'm missing something. Is there some trick to loosen up these screws?
06-08-2012, 11:49 AM   #2
Lowell Goudge's Avatar
try a little heat from a hair dryer. Also some adhesives dissolve in alcohol
06-08-2012, 11:56 AM   #3
QuoteOriginally posted by urje Quote
Some of those lenses have JIS screws, not Philips.
06-08-2012, 12:19 PM   #4
QuoteOriginally posted by lytrytyr Quote
If it is crosshead and on a Japanese camera or lens JIS is pretty much assumed. Use Phillips at your own risk.
06-08-2012, 12:36 PM   #5
boriscleto's Avatar
If you've already stripped the heads, try the rubber band method.
Remove a Stripped Screw with a Rubber Band
Then invest in a JIS driver set so you don't do it again.
06-08-2012, 02:31 PM   #6
Did you foret to remove the do not open sticker?
This is not the way to open a lens and actually there is not way to open and clean a lens for the casual user - for a good reason.
06-09-2012, 02:43 AM   #7
Thanks for the good advice, all! The alcohol I already tried, the hairdryer is up next, as soon as I find a JIS screwdriver. They don't seem to be readily available in Europe, but if I read this jis , it's exactly the problem I'm experiencing. The heads are not stripped yet, but they're also not virgin anymore. We'll see whether it's already too late.
QuoteOriginally posted by zapp Quote
Oh well, I guess I'll just throw the $40 lens away then. And I do think the way to get to the diaphragm is to unscrew the mount and rear lens element, but if you have a better suggestion, I'd be happy to hear it
06-09-2012, 09:27 AM   #8
glasbak's Avatar
You wo'nt access the aperture blades from the bayonet side.
Do you really have oil on the aperture blades, or is that your conclusion because they don't react fast ?
If you don't see any oil, something else may be the problem, I have tried to repair the sticky, but not caused by oil, apertures of various M35/2.8 and M 28/2.8 without much lasting success.
If the speed of opening of the aperture is different between pointing up or down, you may have a lens with the 'sticky aperture without oiled blades' problem.
06-09-2012, 09:31 AM   #9
Micro-Tools Europe Werkzeuge | Miniaturwerkzeuge zur Kamera und Uhrenreparatur
06-09-2012, 10:03 AM   #10
Glasbak: up or down makes no difference, and I can see a bit of liquid on one of the blades. I got the idea that this is the proper route from this site: The Classic Camera Repair Forum: Sticky Aperture - Pentax-M 28mm 2.8 Although I won't be surprised if I can't fix it (or at least not for long), I'd like to try anyway, there's nothing to lose...
Steve: bookmarked! that site seems a lot better than the sketchy 'console and mobile phone tools'-websites I keep running into.
06-09-2012, 10:17 AM   #11
glasbak's Avatar
Front view of a M 28/2.8 model 1:
The m35/2.8 is similar IIRC.
Otherwise, you live a hour on bike from me, just drop the lens on my doorstep .
k-mount, mount, pentax lens, screws, slr lens
Ricoh Rikenon 135mm 1:2,8 (K-mount) vs. Jupiter 37AM 135/3.5 MC (M42 mount) vlazduhu Pentax SLR Lens Discussion 23 02-16-2012 12:57 PM
Ricoh GXR Leica M-mount APS-C module, K-mount next? LFLee Pentax News and Rumors 60 10-18-2011 07:11 AM
For Sale - Sold: FotoDiox K-mount to m43 mount adapter w/ aperture control deejjjaaaa Sold Items 3 08-04-2011 10:06 AM
Trade my Contax/Yashica mount 500mm tokina mirror for a K-mount? ChopperCharles Pentax SLR Lens Discussion 2 05-23-2011 02:44 PM
Hey new here, quick question, is this K mount or M42 Screw Mount? Lulerfly Pentax SLR Lens Discussion 8 11-02-2010 11:58 PM
All times are GMT -7. The time now is 03:59 PM. | See also: NikonForums.com, part of our network of photo forums!
