Originally posted by Philoslothical A given magnification (e.g. 1:1) gives the same result regardless of focal length. That's what I think he was asking. I also explained the relationship of working distance to focal length.
Yes, we can (theoretically) reach any given magnification, using any given focal length, at the right distance. I say 'theoretically' because reality intrudes upon very short lenses on our (d)SLRs. I *could* put 16mm of extension on my Zenitar 16/2.8 and *theoretically* reach 1:1. Alas, the focus distance would put the subject INSIDE the lens. Talk about bad scratches...
Working distance vs focal length breaks down this way with our (d)SLRs:
* Use a 28mm or 35mm lens either if the studio space is very small, or if we want to shoot fairly close without great magnification. A 28mm close-focus lens that reaches about 1:3.5 is great for objects down to about 13cm / 5in wide. A 35mm lens that reaches 1:1 can work (real close!) a subject about 24mm / 1in wide.
* Use a 40mm or 50mm or 60mm lens when you have or need a little more space. My MacTak 50/4(1x) also works subjects about 24mm / 1in wide, but from slightly further away. Hay, the frame is about 24mm and it's 1:1; sure, a 24mm subject fills the sensor! I consider my 40mm and 50mm macros as indoor, studio lenses.
* Use a 90mm or 100-105mm len s for even more space. Use a 150mm or 200mm for even MORE working distance. Longer than that, it gets clumsy. I don't dare put my P.Navitar 254/4.5 on 500mm extension for 1:1! Lenses of 90mm or longer are usually considered outdoor "in the field" glass. Don't scare the mantids.
Have I wandered too far afield here? Rein me in.
Originally posted by normhead If you're over 50 I suggest auto-focus, the old eyes just don't focus so good anymore.
Ah, but AF might not focus on the point YOU want it to. Damn robots...
