06-13-2012, 04:20 AM   #1
Super Takumar vs SMC Takumar
Hi guys,
I have a simple question, lets say for example there are two lenses a Super takumar and a SMC takumar how do they compare?
I know that the SMC is multicoated and will handle flare better compared to the Super Takumar. But in terms of other features how do they differ.
Sharpness? Since they are optically the same they should be equal in sharpness?
Colour reproduction? I am assume that since the one is multicoated and the other is single coated that the SMC will produce more vibrant colours?
Any help would be appreciated. I've owned Super Taks and SMCs but none are the same lenses so I can't do a direct comparison but I noticed that the SMC seems to give great colour all the time but on the Super Taks occasionally they give vibrant colour while other times they seem dull.
06-13-2012, 04:43 AM   #2
causey's Avatar
The SMCs improve contrast. The Super Taks give vibrant colors only occasionally, because they are not protected against light that reduces contrast. It's only when the source of light is behind you that a Super Tak's contrast is optimal.
Sharpness is about the same.
06-13-2012, 09:26 AM   #3
RioRico's Avatar
AFAIK the only difference is the improved coating. Note that are Super and S-M-C and SMC Takumars, with the latter being very similar to SMC (K) PK lenses. A glance through the Pentax M42 database will show where are optical differences.
06-13-2012, 12:56 PM   #4
Lowell Goudge's Avatar
There are some other differences than coatings, as rio suggests, with optical formulas. The most notable and highly debated of these is the difference between the early super tak 50mmF1.4 which has 8 elements, and all other Pentax 50/1.4 lenses which have 7
06-13-2012, 01:23 PM   #5
Blue's Avatar
The coatings on the Super Taks are still not bad for the era. The use of a hood will help minimize possible issues with light. As mentioned, there are some Super Taks and previous Taks as well with some differing and interesting optical arrangements and formulae that weren't made during the S-M-C/SMC era.
06-13-2012, 03:36 PM   #6
Yes I do know not all SupTak and SMC are the same optical formula but if they are the same should I expect the same sharpness in both lenses with very minor deviation due to construction?
06-13-2012, 03:48 PM   #7
RioRico's Avatar
QuoteOriginally posted by epqwerty Quote
Should be. But see the lens reviews for specifics.
06-13-2012, 10:34 PM   #8
Otis Memorial Pentaxian
What he said. I have both Super-Tak 55/1.8 and Pentax-K 55/1.8 and the rendering is very, very similar when both are shot with hoods attached.
(...who never leaves home without his hood...)
06-13-2012, 11:35 PM   #9
RioRico's Avatar
I never leave home without my armored hoodie:
06-14-2012, 07:16 PM   #10
06-14-2012, 09:23 PM   #11
Yeah, I thought the reflectivity of a single coated lens is about 1% vs 5% of an uncoated...there is a figure in the Manual of Photography, p70, of the effects of increasing coatings on reflectivity. Does the multicoating really make a big difference?
Interestingly, the multicoating has differing levels of reflectivity vs wavelength, whereas single coating is a flat line vs wavelength. From this it can be assumed that veracity of colour is better for a single coated lens, but contrast is better for a multicoated lens.
Another point is that some Super-Takumars are apparently multi-coated...
Die Cast Pro - Super Takumar 135mm f/2.5 with Super-Multi-Coating Index
I've got a Minolta CE 50/2.8 enlarging lens which is reputed to be one of the sharpest available, and its accompanying slip says its single coated. In side by side prints vs a multicoated Nikkor 50/2.8, the Minolta appears to have the edge in contrast.
06-14-2012, 10:49 PM   #12
MegaPower's Avatar
I saw this 2 days ago and I am so tempted to buy it.
06-14-2012, 10:54 PM   #13
Banned
Personally, I am interested in old lenses for getting distinctive rendering, so I always prefer less coatings to more modern ones. YMMV.
I have the two versions of the Super Takumar (never looked for an S-M-C or an SMC). They are very close, but the earlier Super has a slightly more distinctive rendering - the second version renders closer to a modern lens and I expect the SMC ones are even more so. For modern performance, I use the Voigtlander Nokton.
BTW, this topic has also been discussed on PF in the past here.
06-15-2012, 12:21 AM - 1 Like   #14
RioRico's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
I just read somewhere that single-coatings give more accurate color rendition, and multi-coatings give better contrast via better flare resistance and light transmission. I put it as: older non-MC lenses give a more 'period' feel. For instance, my single-coated Enna Tele-Ennalyt 135/3.5 gives images a more 'Agfacolor' look than my S-M-C Takumar 135/3.5. Modern optical corrections also seem to give a more uniform look than older simpler glass. This is important when using multiple lenses for vids. But I like distinctions.
colour, k-mount, lenses, pentax lens, sharpness, slr lens, smc, taks, takumar
For Sale - Sold: K20D w/Katz Eye, SMC Takumar 135/2.5 (Ver 2), Super Takumar 105/2.8 kenafein Sold Items 16 04-02-2012 11:41 AM
SMC Takumar VS Super-Multi-Coated Takumar 50/1.4 RolloR Pentax SLR Lens Discussion 5 05-08-2010 06:38 AM
Super Takumar vs SMC Takumar Coatings drewdlephone Pentax SLR Lens Discussion 20 12-31-2009 04:40 PM
All times are GMT -7. The time now is 07:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
