Originally posted by bass3587 I'm heading to DC for vacation and I need some advice on a lens combo to take with me. This is what I have so far. Pentax A 28mm 2.8, M50 1.7, F50 1.7, A35-105mm, kit combo 18-55mm and 55-300 mm. Cameras I have are the K-X and K5. I know I'm going to do a lot of walking so I'm trying to only take two lenses with me. Can you give some suggestions.
Funny enough I have many of these lenses and I used to live in the Washington area (but not when I owned these lenses). If you are going to want to shoot indoors in the museums you need the 18-55. The 28 is okay, but not wide enough on an APS-C camera. You might get away with in a museum like the air and space where you can see the same objects from many vantage points, but the 18-55 will give you a lot more flexibility. It is also a fairly bright museum - not all are. The wider range will also help you frame some of the outdoor shots. As to a second lens, a lot depends on itinerary. For low light priority the F50. For a small, wider, walk around lens you could take the A28, but it doesn't give you that much over the 18-55. The one advantage the 55-300 will give you is that if it is blistering hot, and Washington any time past June can be, you can shoot a lot of the "tourist" pictures without having to walk to every item of interest, but can capture it from a bit further out. I'd probably give the nod to this lens over the F50, unless you can really think of low light areas where you'll want the fast lens. But in a lot of cases, like the galleries, it may prove to be not wide enough to be useful. Aside from lighting issues, the galleries can get very crowded which limits how far back you can stand to take any picture without lots of people wanting to walk in front.
BTW, just north of the galleries is an outdoor sculpture and flower garden worth visiting. I can look it up if you are interested.
