06-17-2012, 11:04 AM   #1
sawtooth235's Avatar
Tripod ring for K-series 300mm f4.0
Does anyone know of a place to buy a removeable tripod ring for a K-Series 300mm f4.0 lens. This lens is quite heavy and I am sure that attaching the camera to a tripod with this lens mounted will put a very large strain on the camera mount hardware. I like this lens and would use it more if it had a tripod ring. Thanks for any suggestions.
Ray
06-17-2012, 11:15 AM   #2
littledrawe's Avatar
This one should work but you have to file off or pop off the white button because that is the part of the lens that this ring sits on, the only part that doesn't turn if I remember correctly. I filed off the white button so the contact with the lens from the tripod ring was consistent all the way around and then I could get the screw turned as tight as necessary to prevent the lens from moving at all.
Tripod Mount Ring for Canon EF 100mm f/2.8 Macro USM | eBay
Then there is the manfrotto bracket that attaches to the tripod socket on the camera and has the arm that goes out to the lens with the strap that wraps over the lens. Lowell should be able to weigh in with his set up soon.
06-17-2012, 11:50 AM   #3
Lowell Goudge's Avatar
I made my own
06-17-2012, 04:45 PM   #4
I got two of the eBay ones, similar to those suggested by littledrawe. One was described as for a Canon 70-200 2.8, which was a bit small (and white), and one for a Canon 100 2.8 Macro, which fits better. Get a few of them and see which one fits best. Err on the side of larger.
I did not need to file down the white dot - I just padded the interior of the tripod ring and fitted it right over the top of the white ball. The tripod ring sits a bit skewed, but that is fine because the foot of the tripod ring still sits flat and perpendicular to the lens on a tripod.
Pic related:
06-18-2012, 04:24 AM   #5
8540tomg's Avatar
Like Lowell I had one made specifically for this lens. The old K300/4 benefits mightily from this addition. See details/images the lens review area in the link below.
SMC Pentax 300mm F4 Reviews - K Prime Lenses - Pentax Lens Reviews & Lens Database
Opinions vary on this lens but I like it.
Tom G
300mm, camera, f4.0, k-mount, k-series, lens, pentax lens, slr lens, tripod
M-Series Free-Spinning Aperture Ring Repair? snake Pentax SLR Lens Discussion 10 06-13-2012 04:31 PM
Cokin P series 62mm adaptor ring rebelcruiser Pentax Camera and Field Accessories 2 10-23-2011 05:19 AM
DA L 55-300mm zoom ring play, gap bwDraco Pentax SLR Lens Discussion 5 12-27-2010 06:46 AM
Replacing F series focus ring indytax Pentax SLR Lens Discussion 6 01-12-2010 08:39 PM
All times are GMT -7. The time now is 10:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
