02-09-2008, 12:23 PM   #16
aegisphan's Avatar
At first, I thought the lens was really soft. But then they were a little out of focus so I was relief. Anyway, the bokeh in the background is indeed ugly (oval shape with highlighted edge). However, photozone did show that the bokeh improves greatly if you stop it down to f2.8. If you don't mind, i would like to see some of shots at this aperture.
02-09-2008, 12:39 PM   #17
FotoPete's Avatar
Yea my Helios-44K-4 58mm f2 does that too. Most of the time the bokeh is alright to very gradual.
Throw in some sharp highlights in the background and those oval bokeh with bright halos show up...ugh..
02-10-2008, 04:09 AM   #18
roentarre's Avatar
Few more sample shots
QuoteOriginally posted by aegisphan Quote
I did a quick test in the backyard. The highlight bokeh are still harsh wide open at f1.4; at f2.8 the bokeh evolves into neutral type and smaller. However, this is again the weakness of most 50mm anyway
f1.4
f2.8
QuoteOriginally posted by FotoPete Quote
Sean did the test of that lens and it performs too. (Now I wonder why I spent so much on this lens :P)
Some other test shots around the house. (Feeling sick today anyway)
All shot wide open at f1.4; The more I use it, the more I wanna use A 50 f1.2 ...
But it gives somewhat smoother feel to the image rendering comparing to A 50 f1.2 probably because voigtlander nokton is a little lower contrast perhaps ...
Backlighting. The jade horses still have the details and flare control is pretty good. Little Ca there
Excuse the dead flowers near by. The lens did pretty well with boke
The bokeh are smooth with warm directional lighting
Then the rest of the shots from the testing protraits yesterday.
02-10-2008, 04:16 PM   #19
aegisphan's Avatar
The last picture really convinces me to get this one. It gives me the feel I got from my FA* 85: her porcelain skin, the bit soften/flattering look on the subject and creamy blurr-out background. The tone is a bit on the cool side, which is similar to most Zeiss lenses.
02-10-2008, 09:07 PM   #20
roentarre's Avatar
The blurr on skin could be potentially due to narrow depth of field though...
02-10-2008, 09:48 PM   #21
aegisphan's Avatar
It's no doubt due to the narrow DOF. However, it lacks the "uneeded" glow like in the 1st picture (in your case because of OOF and not inherent softness at wide aperture). I shot most of my portraits at large aperture; I just focus on the eyes, and fire the shutter. The results really please my subjects, especially women.
All in all, thank you for the samples.
By the way, I forgot to ask. Do you have any overexposure problem that many Nikon users are complaining about?
02-10-2008, 10:43 PM   #22
roentarre's Avatar
No problems. Pleasure to show examples. (I like to shoot wide open too )
Most commonly underexposed with k10d. Needs to compensate at least +2/3 most of the time.
02-11-2008, 04:45 PM   #23
My Nokton arrived today....what a nice piece of equipment. Extremely well made. Nothing at all like any other current modern SLR lens other than the FA limited lenses I have recently bought that I am aware of. I would guess the Zeiss lenses are of similar quality too.
02-11-2008, 06:38 PM   #24
roentarre's Avatar
I had a chance to play around Zeiss 50mm f1.4 and the appearance is similar to nokton 58mm.
The manual focus ring is so smooth and enjoyable to use. The metallic build is really something else. I am still in the processing of getting a proper good UV filter as a protection for the front element.
It looks small but weighs about 300 g or so. Appearance can be deceiving
03-11-2008, 04:32 AM   #25
roentarre's Avatar
Some more Shots update
The bokeh of this lens is smoother and creamy. I love this lens a lot.
For scenery shot in the city on the weekend.
And a great snack
03-11-2008, 04:51 AM   #26
roentarre's Avatar
One more bokeh
04-26-2008, 08:47 AM   #27
knyghtfall's Avatar
I have mixed feelings about this lens - when I first tested it out on slide film, I got very disappointing results! The image was very soft when the lens was wide open, and worse still - the image suffered from very bad blurring, which did not seem to be due to off-focusing. Prints from the FA 50/1.4 were much much better wide open!
I thought I got a lemon then. However, I managed to get a DSLR to test the lens, and was surprised by the images I got. The sharpness was stunning at f2.8, and even at f1.4 - there was still a bit of softness (made more noticeable due to the narrow DOF) but nothing as bad as before. It was then I realised that the blurring was caused by camera shake - most surprising I didn't have the same problem with the FA 50/1.4 or even the FA 77 at similar shutter speeds. Plus, the pictures were taken in very bright lighting conditions!
I no longer have doubts about the sharpness of the lens, but I find that its a very unforgiving "artist" - ths slightest camera shake shows, and badly. On film, I think I would have to stick to 1/90 or above for the nokton 58mm, while for the FA 77 I could still go down to 1/30 and get a decent image!
Have anyone else noticed this about this lens?
04-26-2008, 09:36 AM   #28
is it the heavier weight that's the problem?
04-26-2008, 09:58 AM   #29
knyghtfall's Avatar
QuoteOriginally posted by k100d Quote
You may be right, given that it is a bigger lens than the 50 or the 77.. heh, it may very well be the simple answer to a simple problem.
Will try it out somemore before I come to a verdict. From my experience, it seems to me that the handling of the lens differs from the other SL lens. My rule of thumb for shutter speeds for hand held shots is 1/ (focal length) sec, which has served me well even for the VT 125, which is quite bulky. Quite surprising that this doesn't apply with the 58mm.
for instance, here's an indoors shot with the VT 125 at ard 1/120 s, and it turned out pretty well, even though I was worried about camera shake due to the relatively low shutter speed
04-26-2008, 10:19 AM   #30
QuoteOriginally posted by knyghtfall Quote
the nokton does seem to look like quite a chunky lens, maybe just need more practice
58mm, f/1.4, k-mount, nokton, nokton 58mm f/1.4, pentax lens, slr lens, voigtlander, voigtlander nokton 58mm
For Sale - Sold: Voigtlander Nokton 58mm F1.4 SL II (US) kuau Sold Items 3 08-09-2010 07:46 PM
Lens review : Photo Voigtlander Nokton 58mm hcc Site Suggestions and Help 3 04-30-2010 05:20 PM
For Sale - Sold: Voigtlander Nokton SL 58mm f/1.4 Wheatfield Sold Items 6 07-20-2009 06:19 AM
Voigtlander Nokton 58mm f/1.4 images dave9t5 Pentax SLR Lens Discussion 4 05-19-2009 09:09 AM
Volna-9 vs. Voigtlander Nokton 58mm Voe Pentax SLR Lens Discussion 9 08-20-2008 05:26 AM
All times are GMT -7. The time now is 07:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
