for the Zeiss,... how did you find the bokeh ??
since on photozone.de and some other posts, I heard,
that the bokeh is harsh.
did get the 58mm nokton,... and currently waiting for the katzeye split screen,...
to see, if I could get some decent portrait shots out if it.
also noticed, with IS enabled, outdoors, I'd get more often blurry shots, even with high shutter speeds, focusing is very difficult,... think an eye cup mag 1.2x,... to add,... the more I try, the more I think a AF 50mm is good enough,...
back to bokeh,... on aps,.. shooting 1.4 or 1.7 don't make sense,... since the aperture, does not cover the sensor, as such, it's just diffusion, if you'd like the effect, might as well get a hasselblad softar filter,...
think it needs f2.2 to start cover the sensor,.. as such belive, f2.4 and up is good for this lens, F2.0 still a litle glow , what might be what you'd want.
distance shots and highlights do have BA , but think for portraits, might not be a problem, seam to perform better on closer range.
handling is good, size is small, wish it had a clipon hood,.. did get an alu screw on hood, but is also to short, still makes it usable for buildin flash, what makes it a joy, aka lighter to use,...
next, need to get my old tripod replaced, to have a solid foundation,....
noticed on my Metz, it does not know the focal length, even thought I select it on the body,...
wish for a full frame asap,... so far no new from samsung / pentax,...
meanwhile sony is in the pits,.. .and canon will have a curveball too,..
and nikon be in the race up front,....
now that I develope slowly a nag for good MF lenses,...
the nikon also supports, zeiss and voigtlander,... not to mention , also some nice AIS lenses, ( my buddy has a bag full of them,...if I could only ask,..)
the 35mm AIS 1.4 be a good one too,...
the sony be good too, exept , need to buy sony,.... and the 85mm is $1400,... outch,...
now for an experiment,.... ( thought I did that a lot in the past), I pu on my leftover wcon .7 from oly on the nokton,... not quiet as pritty,... it's 105mm in front,... flares , like no tomorrow,... again,... at 2.4 start shaping up, and at F4,
actually like it better than the zoom, have not done live testing, and convenience wise does not make sense, it's another 2 lbs of glass and steel,... so a 40mm nokton, seams to be more logical,.. that one also comes with a closeup lens, for the pinch,... do mave also a mcon35,... just wonder if there is an say 0.5 or 1.0 diopter closeup lens,... most of them are too strong,... might as well change the lens/macro.
back to my corner, need to raplace my 54mz-3,... no p-ttl, no ttl only auto,..
no wireless, no hss,....... want to try out the ray flash,.. to cover portraits, closup, macro range,... but that one would not work in auto,... and don't want to use manual all the time,...
Originally posted by TKH I owned the Zeiss for a few weeks and now use (and love) the Nokton.
Have I to say more?
The Zeiss is a fantastic lens. The Nokton is a lit bit more creamy from 1.4 to 2, and the colours are a bit on the warmer side. The Zeiss is steped down perhaps a lit bit sharper. The Nokton is made very, very good, the Zeiss is perfect.
Best,
Rainer
