06-18-2012, 09:55 AM   #1
cali92rs's Avatar
Revuenon 55mm f1.2 Initial Impressions
I just bought a Revuenon 55mm f1.2 from a fellow board member I did some preliminary shots this weekend.
If you are looking for a lens that is super sharp wide open, this isn't the lens for you. But if you want a lens that gives a real painterly look, with the smoothest creamiest bokeh around, give this lens a look I already have a FA 50mm f1.7 which is really sharp, so I didn't want another one.
I have a feeling that this lens wouldn't look great on MTF charts, but it does have that certain soft, pretty rendition that gives you a dream like feel. Is that what some members mean by "pixie dust"? LOL
Anyway, I think I am in love
Only drawback with the lens is it has a long minimum focusing distance. I have some extension tubes I will play around with to see if I can get a bit closer.
Also, and this isnt lens related, the K-5's stock focusing screen is definitely not up to the challenge of a f1.2 aperture. I was using LV plus magnification. Here comes the EE-S focusing screen
06-18-2012, 10:35 AM   #2
radium's Avatar
Hi if you like photographing close ups maybe a 50mm macro lens because you said your new lens doesn`t focus close enough? Ok, I just noticed that you have the 100mm macro lens. I guess you were just testing your new Revuenon 55mm F1.2 lens ? Nice and dreamy creamy effect. Too bad Pentax never made an auto focus 50mm F1.2 lens and for that matter stopped making the Pentax 50mm F1.2 lenses all together.
06-18-2012, 11:22 AM   #3
QuoteOriginally posted by radium Quote
Too bad Pentax . . . stopped making the Pentax 50mm F1.2 lenses all together.
Wasn't the A 50/1.2 still available new in some markets recently?
Interchangeable Lenses (for 35mm SLR Cameras) : Film Cameras | PENTAX RICOH IMAGING
Pentax 50/1.2 | Flickr - Photo Sharing!
06-18-2012, 01:03 PM   #4
Banned
QuoteOriginally posted by cali92rs Quote
Are you the new owner of kenafein's Revuenon? I have the Cosina branded version and it is as sharp as it needs to be wide open - but so little will be in focus at that aperture that people will call results soft, but that is just what thin DOF looks like.
I have not tried it for flowers yet, but for low light scenarios, this lens is excellent. You should also make sure to use a hood with it, otherwise flare and reflections will affect the resolution, especially when using it wide open. A CPL might help to cut reflections on flowers - the loss of stop shouldn't matter when you use it wide open.
You have a great lens there. You should also try it at other apertures - I like its rendering at f/2.8 for people shots.
06-18-2012, 02:24 PM   #5
cali92rs's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
Yes I am...a great guy to deal with
You are correct, I misspoke when I implied that it may be soft. The OOF areas just dominate the in-focus areas and just give that appearance
Thanks for the tips...i have never thought to use a CPL for flowers, but that does make sense
06-18-2012, 07:07 PM   #6
Wonderful lens. I almost got it myself from kenafein, but decided it was too much money for a lens I wouldn't be able to focus.
So, instead, I ordered a proper focusing screen and will practice with my 1.4 until I learn to get it right and then look for another one.
I am in love with it, and I didn't even have a first date yet.
06-20-2012, 02:19 PM   #7
Porga's Avatar
Maybe is a copy issue. Mine copy is sharp wide open. Nowhere near soft. I have F 50/1.7, and to be honest, I don't se any real difference in sharpness, of those two lenses. maybe I have a softer F 50 lens who knows.
06-21-2012, 11:19 AM   #8
cali92rs's Avatar
Laurentiu, do you have a hood recommendation for this lens?
06-21-2012, 11:38 AM   #9
I have found a round metal screw-in hood to be a good match for this lens.
Personally, I use this one on my Cosina version, with a 58-62 step-up ring. Works great, with no perceptible vignetting despite being a hood intended for tele lenses. (55mm is tele, sure, but not by much!)
And because the hood comes with a cap that fits the outside of the hood, I keep it on all the time. It protects that giant glass eyeball on the front of the lens quite nicely.
06-21-2012, 12:01 PM   #10
cali92rs's Avatar
QuoteOriginally posted by Quicksand Quote
Interesting...is the bottom meant to flex?
Thanks for the info
06-22-2012, 12:51 AM   #11
Banned
+1 for the hoods that heavystar sells. Very sturdy and they match black lenses very nicely. I use a 58mm TELE one with the Cosina 55/1.2.
06-22-2012, 01:21 AM   #12
Porga's Avatar
Mee too.
06-22-2012, 01:28 AM   #13
steve1307's Avatar
oh right..... I got the "normal" lens length version one as I thought the tele version might be too long even with APS-C sensor.
Looking at the size of the DA*55's hood it should be obvious.
Even so it does help though.
55mm, f1.2, flickr, k-mount, kenneth, lens, look, marks, pentax lens, revuenon, revuenon 55mm f1.2, screen, slr lens
Initial impressions of a K5 sabarrett Pentax K-5 & K-5 II 7 03-29-2011 08:03 PM
DigLloyd just posted his initial 645D impressions leping Pentax Medium Format 16 02-01-2011 09:55 PM
645D - Short test and initial impressions. Warped Pentax Medium Format 14 07-12-2010 05:39 PM
K-7 Initial Impressions Wheatfield Pentax DSLR Discussion 32 07-06-2009 09:37 PM
Initial K10-D Impressions -=JoN=- Pentax DSLR Discussion 2 11-22-2006 05:17 AM
All times are GMT -7. The time now is 12:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
