Originally posted by writerman Which would be best for photographing oil paintings with a K-5 — a DA 40mm or DA 35mm macro? Or is there another, better alternative?
As I understand, macro lenses are designed for a flat focus plane, so I expect it would be better. Of course, if you have a tripod or enough light to stop down, either would be an excellent option. There is also a slight difference is focal length; I assume that changing your working distance isn't a problem?
The most important part is probably taking a shot at exactly the right angle and framing.
If you take the time that you'd need to anyway to setup the shot really well, you might prefer a manual focus lens anyway. How about an older 28mm f2.8 if you're on a budget?
