06-25-2012, 10:50 PM   #61
Anvh's Avatar
Uhmmm you're the first to come with personal attacks so dont come with me that i cant read, besides you kept mixing things up with our last conversation so if i did read something wrong then don't lay the blame with me.
Repeating yourself won't help because that's what you're doing now since i can simply repeat myself as well so it will become an endless loop.
And you didn't give me a book, you gave me a quote out of a book and to that quote i simply said it was bullocks. Since you say you've a degree in biology then it would be quite simple for you to dismiss my claim why it's bullocks, since you haven't can i presume i'm correct?
Very funny you come with a link that doesnt explain anything or add something, how meaningless.
Well for fun shall we actually discuss it.
This is roughly the same as the angle that the human eye can comfortably view, which is why it gives a natural-looking perspective .
Okay since you've a biological degree please explain to me what the definition of "comfortable view" is, if it even means something....
Now the second part "natural-looking perspective", well here we go the definition of perspective.
the appearance of objects, buildings, etc., relative to each other, as determined by their distance from the viewer, or the effects of this distance on their appearance
Great actually nothing concrete about field of view in that so how does the word "perspective" works in that sentence?
06-25-2012, 10:59 PM   #62
Blue's Avatar
QuoteOriginally posted by Anvh Quote
I wrote the book title, year and author in that post. Go to a bookstore or library or Amazon. I also posted the article about the FA 43. I have discussed normal and standard lens in the context of the FA 43 and DA 40 all I intend to for now. As a matter of fact, I have 3 biology degrees. However, if you want biology tutoring, Tallahassee is probably way out of your way. However, if you are ever in town, I can probably get you a discount. In the mean time you are back on the Ignore List.
06-25-2012, 11:12 PM   #63
Anvh's Avatar
As far as biology stuff goes,the foveal region is surrounded by the parafoveal region while the 1 to 2 degrees of the foveal region is the sharpest. However, the parafoveal can go up to 30 degrees into the near periphery. It is about the perspective created. If you look, you will see that Hedgecoe said eyes and not eye. However, this is the reason a numerical definition or rule was adopted by some to describe a normal or standard lens. The point is that a standard lens will give closer to a natural view of a subject than wide angles or telephoto lenses.
Wow you're improving, you go from an insult to actually explain yourself when you edited your comment.
But isnt the parafoveal belt part of the periphial vision and since the quote clearly say nonperiphery i'm missing the connection...
06-25-2012, 11:15 PM   #64
Anvh's Avatar
Thanks for explaining nothing, i wonder why i even bothered.
Every time i asked you to explain yourself you can't and when i press on you put me on the ignore list, is it so hard to explain something for you or are there other problems?
Well i can see why you're giving away discounts if you also teach like this...
06-26-2012, 01:51 AM   #65
glasbak's Avatar
Well, this 'discussion' started probably because of Anvh reply to my message.
Anvh wants probably to show his wiki knowledge, but for photography, his message boils down to what I stated in the first place, take the diagonal.
I replied to 'builttospill', because he threw in '100% viewfinder magnification'.
And that is generally defined when using a certain focal length, usually close to the 'normal', except for APS-C, where camera builders specify it at 50mm, so it looks better on the spec sheet.
So can we stop throwing mud ?
06-26-2012, 09:50 AM   #66
Anvh's Avatar
Wiki knowledge, then you don't know me well enough i almost never quote them or actual use them for meaningful information so don't pretend like you know me.
Besides i never said that taking the diagonal of the formatt was wrong, i only make a point that that isn't a true definition because it doesn't explain what a normal lens actually is and why it's called normal and i haven't seen or heard anything to change my mind on this.
It just happen to be the diagonal of the formatt for general use at least because if we get situations where the photo isnt viewed normally then we need to take that into account to get a natural looking perspective.
if you want my own words what normal lens is then a normal lens is the lens that gives you a normal perspective with your final image so it isnt a fix value really.
06-26-2012, 12:25 PM   #67
I think that you guys slinging mud at each other should get off my thread. The question I asked was answered, clearly and with documentation, several posts ago. Thanks to those who posted constructively.
06-26-2012, 12:37 PM   #68
Ben_Edict's Avatar
Apart from the Wiki-related discussion: NO lens gives you a perspective. That is only common misconception. Perspective is a result of distances (from photographer to subject - to other parts in the image).
What you might mean is the "normal angle of view". But what is that? The discussion about the sharpest regions of vision in the eye is going in the right direction, I think, because it doesn't lead to a real conclusion and surely not to a sharply defined rule. I find the definition of a "normal" field of view highly individual. In 35mm film days, my personal "normal lenses" where the 35mm and the 80mm. The 35mm lens would roughly put on film, what I see and perceive when I look at a wide scene. But the moment I concentrate on something interesting, my brain blends out all the lesser important stuff and my angle of view (or of perception) is then represented best by the 80mm lens.
This individuality is one reason, why a simple technical definition of the "normal lens" as having a fl app. the length of the film format diagonal is useful and meaningful. By the way, I did not quote the full length of the Encyclopedia of Photography entry, it is longer and also refers to the 52 deg field of view, associated with a normal lens etc.
Ofcourse there is a relationship (historically) between the normal lens and human vision, but if you just look up the in-depth discussion of this relationship (as given for example on page 201 in Ray's "Applied Photographic Optics") it is quite clear that the "natural" look a "normal" or "standard" lens is expected to provide is mostly a heresay wisdom. It certainly does not apply to the 35mm format, but derives from old and obsolete "whole plate" prints at the time, when prints would not be enlarged, but contact printed. For 35mm and other "small" film formats (129 or whatever) you also need to account for enlargement factor etc. That is, why I think, that any perception-based definition of a normal lens is arbitrary.
Ben
06-26-2012, 12:46 PM   #69
Ben_Edict's Avatar
QuoteOriginally posted by Virginia Bill Quote
I understand your feelings, but openly posted threads often evolve like that. I do not quite understand, why personal insults need to be written down, but some people seem to have a need for that.
Nevertheless going back to your initial question: You are coming from Nikon. Nikon had a famous "normal" lens in its portfolio back in the 70s/80s: The Noct-Nikkor 58mm/1.2. 58mm was quite a bit long for a normal lens, but today we have 60mm macro lenses on the market, which is not far off. Also, you should also take into account, that real focal lengthes are often somewhat different from what is engraved or printed on the lens barrel. Even the very first 50mm standard lens for the first Leica had 52mm fl in reality. So, Pentax could have sold the FA 77mm Ltd, easily as an "80mm" lens, if they had wished to do so, without any complaints from customers.
Ben
21mm, 40mm, crop, culture, design, k-mount, lengths, lens, lenses, pentax, pentax lens, primes, slr lens
Comparing 50mm focal lengths... Again. Mareket Pentax SLR Lens Discussion 8 05-08-2012 05:57 PM
FA limited focal lengths Anvh Pentax SLR Lens Discussion 36 04-17-2012 11:30 PM
Focal lengths and large format - Noob Questions David-C Pentax Medium Format 11 01-04-2012 07:10 PM
Sensor size v Pentax focal lengths wizofoz Pentax DSLR Discussion 18 10-12-2010 04:23 AM
DA* and focal lengths emr Pentax SLR Lens Discussion 11 10-06-2009 11:51 AM
All times are GMT -7. The time now is 05:44 AM. | See also: NikonForums.com, part of our network of photo forums!
