06-26-2012, 08:52 AM   #1
slip's Avatar
Tamron confusion
I am looking at an old tamron 300mm auto 5.6
the problem is I can't match it to any I look at in our index
all the 5.6 lenses I see don't have a tripod mount, but this one does.the collar around the end of the lens can extend to be used as a lens hood.
serial 22210
Is it an adaptall?
any help appreciated
found a pic
has a minolta mount
randy
06-26-2012, 09:00 AM   #2
QuoteOriginally posted by slip Quote
serial 22210
Is it an adaptall?
randy
Try looking at adaptall-2.org
06-26-2012, 09:03 AM   #3
slip's Avatar
thanks, but couldn't find the same copy on the site
randy
06-26-2012, 09:14 AM   #4
minahasa's Avatar
Not this one? The site says there are several versions
Tamron Adapt-A-Matic 300mm F/5.6 Model 670Au
06-26-2012, 09:23 AM   #5
slip's Avatar
QuoteOriginally posted by minahasa Quote
that looks right
Is it any good?
I am not sure but the version I was looking at wasn't knurled, but is likely on of the 3 mentioned
what mount would it be?
thanks for the help
randy
06-26-2012, 09:39 AM   #6
minahasa's Avatar
that looks right
Is it any good?
thanks for the help
randy
Never had this one, but I have the 135/2.8 Adapt-A-Matic in interchangeable mount, mine is M42 Like all Tamrons from this era (including the newer Adaptals), it is build like a tank. Optically, well, that depends on many things, I suppose.
06-26-2012, 02:17 PM   #7
Blue's Avatar
randy
Did you look under the Adapt-a-matic link? Some of them are pretty good like the 105mm. I also like the 21mm on film. I don't have any experience with the longer Adapt-a-matics. The 105 is the hardest to come by.
06-27-2012, 08:42 AM   #8
drougge's Avatar
I have one of those, never really tried it properly. Front element rotates when focusing, A/M switch is a bit stiff, aperture has a "flower" shape when not stopped down very much.
The mount is of course adapt-a-matic, just like it says all over the place. This is not compatible with adaptall, or any other mount that is not named adapt-a-matic. Adapters are probably not particularly easy to find without lenses, but with shouldn't be so hard. (No PK adapters exist, but M42 seems pretty common.) Depending on the age of your lens, it may not even be compatible with all adapt-a-matic adapters, as there are two generations, and I'm not sure if they are mutually compatible.
06-27-2012, 11:59 AM   #9
I have a 300 5.6 AUTO_TAMRON in silver. I think it is a transitional version because it uses the Adptall-2 series of mount. My son used it a bird sanctuary last fall and he took some very good hand-held shots with. High detail at distance and incredible colours. PF for sure but for us a lot of fun for $60.
06-27-2012, 12:49 PM   #10
Blue's Avatar
QuoteOriginally posted by drougge Quote
That is because they were discontinued before the K-mount was released.
k-mount, lens, pentax lens, slr lens, tamron
Prism Confusion Hummingbird Pentax Medium Format 7 04-12-2011 03:59 AM
A little confusion over my Tamron Adaptall II 28mm f/2.5 minahasa Pentax SLR Lens Discussion 12 03-30-2011 12:14 PM
Metering confusion Stardog Troubleshooting and Beginner Help 6 03-29-2011 12:28 PM
645D Confusion Joburger Pentax Medium Format 43 01-27-2011 01:13 PM
Tamron Adaptall Mount Confusion ChipB Pentax SLR Lens Discussion 12 07-16-2010 08:57 PM
All times are GMT -7. The time now is 11:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
