Thanks for all the info. This lens was bought as part of a lot, although it was the one I had highest hopes for.
I didn't have lighter fluid but I did work some alcohol into the blades several times, as described, with a bit of wiping off in between. At this point the aperture seems to be working pretty well.
I also cleaned the outside of the lens body with alcohol since there seemed to be oil on that too.
If I continue to have problems I will definitely try the naptha or lighter fluid - Thanks for the advice.
With the lot that I bought, if you figure the cost per item, I paid just about five dollars for this lens, and I didn't even have to pay shipping so... If I can do this quick fix on this lens, I can't complain too much
Thanks again all!!
