06-29-2012, 11:08 AM   #16
Mareket's Avatar
And a picture at f/128 with said lens (bear in mind I positioned the K-5 half-arsedly with a gorillapod, so the plane of focus is most definitely not parallel to the plane of the sensor):
06-29-2012, 11:13 AM   #17
eddie1960's Avatar
QuoteOriginally posted by lytrytyr Quote
Even RioRico would have a challenge adapting this to Pentax!
you'd be surprised what @RioRico can do with a bellows or an flanged adapter and some glue and extension tubes
Edit, I have seen a lens much like that adapted to a canon and shots from the streets of new york
http://blog.planet5d.com/2010/09/what-do-you-get-when-you-put-a-102-year-old...os-5d-mark-ii/
06-29-2012, 12:05 PM   #18
kh1234567890's Avatar
QuoteOriginally posted by victordeamorin Quote
Also, on a more trivial note, I believe the kit 18-55 lens goes at leat to f/44 when zoomed at 55mm. Too lazy to check the exact value now... But it is probably also applicable to other variable aperture consumer zooms.
f40 if you set third of a stop aperture increments
06-29-2012, 12:16 PM   #19
eddie1960's Avatar
interesting, not a great test of diffraction though since iso 1600 on the k7 is already limited. at full size what looks sharp at web sized is softer though - but it could be many things (iso, diffraction, or just the fact that the kit isn't at it's sharpest at 55 anyway). But it does show that diffraction isn't a major concern if you are posting on the web, or using the image in less sharpness critical situations.
the real measure would be the same shot better lit so you could shoot iso 100 and shoot it at 5.6/8/11/16/22/40 and be able to compare relative sharpness under a controlled test
Ultimately though there are many other things that are more important to an image than ultimate sharpness
“Sharpness is a bourgeois concept” - Henri Cartier-Bresson
06-29-2012, 12:33 PM   #20
It did have a cheap Sony VCL-M3358 close-up lens stuck on the front of it Found it in my drawer (from my Sony DSC-H1 days) and thought 'what would happen if ...'. ISO1600 'cause I couldn't be ars*d to get the tripod set up and was shooting hand-held. As you say, it looks sharper than it is.
06-29-2012, 12:44 PM   #21
normhead's Avatar
Putting the Pentax FA 1.7 TC on a DA* 60-250 will get you to F 57. But despite many exposures, we often shoot with wide open 5.6, 8, 11, 22, 32 and select the best image... we've never selected a shot above F 22 as the best shot...and most shots fall in the range of 5.6 to 8 with diminishing returns after that. We've never even selected an F-32 shot. By that time the image is so softened by diffraction you really don't care if it's consistently sharp across a very wide depth of field, it's just bad.
06-29-2012, 12:44 PM   #22
eddie1960's Avatar
QuoteOriginally posted by kh1234567890 Quote
There are a few examples on flickr of diffraction of say F16 versus F32 . when you look at the web size it's not really apparent but when you look at the full size the sharp edges all have a soft glow.
If I needed to shoot F22 to get a composition i wanted I probably would bearing in mind I won't be printing it at 30x40 for sale
06-29-2012, 01:52 PM   #23
cali92rs's Avatar
The OP hasn't responded in 2 pages to what he wants to accomplish...greater DOF for macro or landscapes, or longer exposures.
I am not a great landscape shooter, but for macro focus stacking works wonderfully if done properly. I am curious for the landscape shooters that like vast DOFs, does focus stacking work for that application as wel?
06-29-2012, 02:06 PM   #24
Otis Memorial Pentaxian
QuoteOriginally posted by Medium FormatPro Quote
If f22 or f32 isn't quite good enough...
It all depends on what you mean by "good enough". The smaller apertures don't do much for performance, but they are pretty much essential for depth of field, hence their presence on lenses for large format cameras.
As noted above, if you need longer exposure times, a neutral density filter is your best friend.
f22, f32, k-mount, pentax lens, slr lens
Lens greater than F32 schitzengiggles Pentax SLR Lens Discussion 22 06-09-2012 11:59 AM
Carl Zeiss Lens, 35-70mm F2.8-F22 ozlizard Pentax SLR Lens Discussion 7 10-06-2011 04:48 AM
What about this? Tokina is good stuff isn't it? Raptorman Pentax SLR Lens Discussion 5 04-22-2010 02:39 PM
Macro at f32! And some other stuff... codiac2600 Post Your Photos! 10 07-01-2007 01:34 PM
landscapes... which lens is sharpest at F16 to F32 etc? slip Pentax SLR Lens Discussion 7 01-06-2007 07:41 PM
All times are GMT -7. The time now is 09:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
