Originally posted by StephenHampshire The 18-135 is scarcely bigger than the 18-55 and so much more versatile.
Agree that the 18-135 is only slightly bigger than the 18-55 when mounted, but when in use, at focal lengths greater than 18 mm, the zoom extends considerably, compared to the 18-55 which barely extends at all. The lens hood on the 18-135 is larger (as it should be), so that makes the whole kaboodle bigger too, when the hood is mounted (as it normally should be).
The 18-135 is also noticeably bigger when looking directly into the front element, from your subject's point of view. The filter threads are 62 mm vs. 52 mm which doesn't sound like much, but the actual difference in the glass element is more than that due to differences in the trim bezel surrounding the glass -- so the 18-135 has a much bigger eyeball, glaring at your subject.
The 18-55 is half the weight than the 18-135.
The 18-55 also has a "macro" range on the focus scale which yields magnification around 1:3. Not real macro, but it certainly focuses closer than many other lenses which are marketed as macro lenses.
These are just my personal excuses for keeping my 18-55 around. None of these points should discourage a potential 18-135 buyer. As I said before, I use the 18-135 as my default lens. When mounted on the compact K-5 body, I want to quote Tony Montana: "Say hello to my little friend", ha ha.
Originally posted by JinDesu It is considered very quick, mostly silent, and very reliable.
While the SDM motors in the DA* lenses motors are completely silent, I would still characterize the DC motor in the 18-135 as silent, for all intents and purposes. You can hear the motor, but your head is next to the camera. It's much quiter than the dust removal sound you get when you power up a K-5.
