I was just wondering about filter options for this lens. Will a standard 82mm filter work? I am looking for ND filters to fit this lens. Was going to get the Hitech 100mm filter system but not too keen on spending that much money on filters that I'll use on only 1 lens.
What I'm interested to know is, will the HOYA ND400 82mm filter fit on the lens without touching the font element? It looks like the lens sticks out slightly past the thread.
I was thinking of buying this filter unless there is something better quality out there:
http://www.ebay.com.au/itm/Brand-New-Kenko-82mm-82-mm-MC-ND400-Filter-ND-400...item4ab890f64f
EDIT: What is the difference between the HOYA and KENKO filters?
http://www.ebay.com.au/itm/Hoya-HMC-49mm-ND-400-Neutral-Density-MC-AUTHORIZE...item4d029f0741
