07-09-2012, 03:45 PM   #1
135/3.5...which one?
Which would you rather keep an excellent condition Super-Takumar or a very good Super-Multi-Coated Takumar? Both glass is very clean.
07-09-2012, 11:28 PM   #2
The SMC version will exhibit less flare, so I'd keep that one if you use it a lot.
07-10-2012, 02:19 PM   #3
Lowell Goudge's Avatar
are you a collector or a user.
a collector would keep both, a user would keep the smc tak assuming glass and aperture function are equal in both,
07-10-2012, 04:01 PM   #4
Hi Lowell, I am a collector alright, but I have this sickness....I keep buying and buying and buying....I think I need to go to a 12 step photo equipment group!!
I think you are right about the SMC...
thanks for your input.
07-11-2012, 06:22 AM   #5
QuoteOriginally posted by durr3 Quote
and your problem is???
right, if you join let me know, i will help you divest your problem
the SMC by all accounts should be better, and as I recall the lens formula is the same. sometimes this is not the case, and the smc vs super tak lenses can have different renderings, which can influence the issue.
My M42 kit, and yes, i have one with 14 lenses from 16 to 200mm, although having some SMC taks, largely is of other lenses just to be different than my K mount kit which does have a large percentage of K and M lenses for just that reason
k-mount, pentax lens, slr lens
Extreme Corner Performance Shootout - FA 43mm vs DA18-135 vs DA*50-135 chesebert Pentax SLR Lens Discussion 4 05-22-2012 09:38 AM
XR Rikenon 135/2.8 OR Carl Zeiss Jena 135/3.5 (zebra) adicaciula Pentax SLR Lens Discussion 2 02-20-2012 02:29 AM
Move from 18-135 to 16-50 + 50-135 DA* Lenses brosen Pentax SLR Lens Discussion 34 11-08-2011 05:11 PM
Takumar 135 2.5 vs Super Tak 135 3.5, both bayonet mount, which is better? chongmic Pentax SLR Lens Discussion 7 04-09-2011 11:55 PM
All times are GMT -7. The time now is 10:48 AM. | See also: NikonForums.com, part of our network of photo forums!
