Originally posted by top-quark Problem is the "handheld" bit. I can tell, for example, the top image in the first pair is softer than the second, but is this down to the filter or to you missing focus a little? To test this properly, you need to eliminate variables: which means on a tripod, one shot with, one without, don't refocus between shots.
I'm a pretty steady-handed guy and all shots were at 1/500th or higher, which I thought should be ok at 300mm, especially with shake reduction also on.
I refocused (with the autofocus locking on each time) in case the presence of the filter affected the accuracy of the AF.
I tested for my own benefit, because I'm planning on using this lens a lot at the long end, handheld. The Tiffen filter downright sucked, and I wanted to know if it was because of that particular filter, or a UV filter in general that was responsible for the poor image quality. Turns out, it was just the Tiffen filter at fault.
I can repeat the test with a tripod using whatever method is deemed "proper", but some will always say something is out of whack.
If you guys are done, I can pop up the results anytime.
Cheers,
Bobbo :-)
