07-14-2012, 08:36 PM   #16
dms
No actually the focus is shifted by a fraction of the filter thickness--1/4 as I recall--but anyway it is. That is why Kodak Wratten filters are sometimes better (much thinner). Also for critical work clear filters of the same thickness as the other filters are used--so the point of focus is consistent as one changes filters.
07-14-2012, 08:51 PM   #17
dms
lytrytyr, my apologies, you were correct about the filter not having an effect for light coming from ** infinity **, DMS
07-15-2012, 05:34 AM   #18
DMS, I can certainly see how oblique rays would get kicked aside,
so the effects you describe would be relevant for closer objects.
07-15-2012, 06:37 AM   #19
demp10's Avatar
QuoteOriginally posted by lytrytyr Quote
A well-made filter should be plane,
so shouldn't make any geometric change
to rays coming in from infinity.
A filter is another element,and as such it will have some effect (may be negligible) to the entire system. Everything has manufacturing tolerances and nothing is perfectly plane. That's why for lenses that accept drop-in filters, the manufacturer provides a clear glass filter to be used always when a real filter is not needed.
Allowing focusing past infinity on long telephotos will accommodate (and correct) any deviations from all variables in the system.
infinity, infinity focus, k-mount, pentax lens, slr lens
Using old screw mount asahi lenses wont focus to infinity??? carlyn.warnock Pentax SLR Lens Discussion 19 11-28-2012 10:24 AM
Pentax K20D & M42 Lenses Infinity Focus Question kopimorning Pentax SLR Lens Discussion 4 07-17-2010 05:56 PM
infinity focus adjustment on M42 lenses Lowell Goudge Pentax SLR Lens Discussion 11 08-20-2009 01:49 PM
Setting focus for infinity question? 7.62lew Pentax SLR Lens Discussion 5 10-13-2008 11:30 PM
Voigtlander SL lenses - Infinity focus question thePiRaTE!! Pentax SLR Lens Discussion 29 10-30-2007 10:22 AM
All times are GMT -7. The time now is 04:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
