07-15-2012, 11:51 PM   #1
Flash (Metz 36 A-5) not firing with Zenitar 16mm f/2.8
I hope I'm posting this in the correct area. If not, I apologize. I decided to get out my camera (pentax k-5) and my Zenitar 16mm and take some practice shots around the house. I had the camera on manual mode, as usual with this lens. Adjusted the aperture ring ( anywhere between 6-11.... Just playing with different settings). I had iso set to 1600, and shutter speed around 1/50-1/80. I wasn't getting bad pictures... But our lighting in the house makes everything look yellow. So I wanted to try out my flash. NOOOOOOOPE. Wouldn't fire. It turned on. It was ready to fire. But would not fire with this Lens. I tried everything. Went outside in the pitch black dark, still wouldn't fire. Then I put on my 18-55 lens. Fired every time. No problem. I've been on google the past hour trying to figure this out, with zero luck. All I've found out is that this lens is completely manual, and doesn't "communicate" with the camera body at all. Ok... All that being said... Has anyone else experienced this ? Is it impossible to use my external flash with this lens ? Thanks in advance for the advice and replies.
07-17-2012, 04:07 AM   #2
sterretje's Avatar
QuoteOriginally posted by Isnwm Quote
I think that that is the case. Your flash can only do pTTL; no automatic mode or manual mode. If I'm not mistaken, the camera does not use / support pTTL with manual lenses so the flash will not fire.
Select tungsten WB on the camera might be able to solve that.
16mm, camera, fire, flash, flash metz, house, k-mount, lens, pentax lens, slr lens, zenitar
For Sale - Sold: FA 43, FA 77, DA 50-135, Sigma 8-16mm, Tamron 17-50mm, Metz AF58 flash innivus Sold Items 22 04-23-2012 05:12 PM
Zenitar 16mm all M-42 mounts? GerryL Pentax SLR Lens Discussion 7 05-22-2011 07:38 AM
Zenitar 16mm/2.8 FE...where to buy now... dwhopson Pentax SLR Lens Discussion 3 02-04-2011 03:29 AM
Zenitar 16mm on Spotmatic F? iht Troubleshooting and Beginner Help 4 09-13-2010 03:30 PM
All times are GMT -7. The time now is 04:01 PM. | See also: NikonForums.com, part of our network of photo forums!
