07-17-2012, 02:55 AM   #1
Albert Siegel's Avatar
60-250mm vs 300mm at long end?
I was wondering if anyone could give me their thoughts on this... I have the 60-250mm and love it. The only thing that bothers me is at close distance, it hardly gives me any better magnification over my 50-135. Focus on anything far away, then the lens really shows what it can do. That's some heavy focus breathing!
Does the 60-250mm really do 250mm? How does it compare to the DA* 300mm for the long end? Would the DA* 300mm really be worth it to get really close up on a subject indoors vs the 60-250?
Can anyone with both photograph and compare? Perhaps be so kind as to post photos? Thanks a billion for any help.
07-17-2012, 03:36 AM   #2
Sandy Hancock's Avatar
I have both. I'll see what I can do over the next few days.
07-17-2012, 03:52 AM   #3
sterretje's Avatar
The DA*50-135 actually gives you a little more magnification than the DA*60-250; it's so little that it can actually be ignored (both are around 1:6). Check the specs. DA*300 gives a bit more magnification (1:4). Your limitation is actually the minimum focusing distance of those lenses, not the focal length.
If you really want closeups indoors, get a macro lens 1:1 magnification at short distance (DFA100WR, 30cm) to very short distance (DA35Ltd, 14cm).
07-17-2012, 03:53 AM   #4
Ben_Edict's Avatar
QuoteOriginally posted by AlbertSiegel Quote
The 60-250 has IF (internal focusing). Basically all lenses with IF will decrease in effective focal length at near distances.
Ben
07-17-2012, 04:38 AM - 1 Like   #5
steve1307's Avatar
I worked it out in another discussion somewhere that is according to its magnification and minimum focus distance specs its only 125mm !!! at MFD and zoomed to 250mm.
Using the same calcilation from the specs page the DA*300 at MFD seems to be equivalent to 219mm.
Here: https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/178902-pentax-...ml#post1866924
07-17-2012, 05:00 AM   #6
Banned
Yes really does the 250mm still at f4.
Assuming that you ean the Sigma 300mm f2.8... Then the Sigma gets you 1.2x closer but at a considerably better aperature. Not sure off hand what the close focusing distances and rations are when comparing both though.
For true close up I'd consider the Sigma 150mm macro (at about eleven hundred retail) or even waiting for the Sigma 180mm macro. Even the Pentax 100mm macro is impressive.
07-17-2012, 08:36 AM   #7
imtheguy's Avatar
Although my Tammy 70-200/2.8 is my fav glass for walking about and getting occassional bug/flower closeups, I discovered how well the da*300 can do when returning home and finding a Robber Fly blocking the door. Handheld (and SR accidently turned off), pop-up flash due to dark entrance and I was highly impressed with the results.
I have used the da*60-250mm but never shot a closeup like this with it.
07-17-2012, 04:52 PM   #8
Thanks! I'm looking forward to it! Highly appreciated!
QuoteOriginally posted by sterretje Quote
Thanks for the info. Yeah, it's pretty close. My main concern was not macro level shooting, but a close headshot during a press conference or limited space. I just don't get any better a result with the 60-250 than I do the 50-135 sometimes.
QuoteOriginally posted by Ben_Edict Quote
Ben
Thanks for that info. So then my old FA80-200 would not have this issue?
QuoteOriginally posted by steve1307 Quote
This is exactly what I was in need of! Thanks so much for this! It seems that the DA*300 will be bought.
QuoteOriginally posted by imtheguy Quote
Thanks for that! I never knew you could get so close with the 300. Very nice shot!
07-17-2012, 05:47 PM   #9
joe.penn's Avatar
The DA*300 can get you very close - here is one at max magnification (no cropping):
The DA*300 is the ultimate butterfly, dragonfly and flower bud lens...
07-18-2012, 02:36 AM   #10
Ben_Edict's Avatar
The old FA 80-200/2.8 is also IF and will exhibit the same behaviour. But it won't be so obvious, as it gives you a lower max. magnification anyway (x 0.19).
Ben
07-18-2012, 05:15 AM   #11
Ben
I wish it were the 2.8! I should have been more clear. Sorry about that. It's the 4-5.6/80-200mm. :-(
07-18-2012, 06:28 AM   #12
audiobomber's Avatar
QuoteOriginally posted by Medium FormatPro Quote
That is correct regarding aperture, but the range only reaches 250mm at infinity focus. As shown in Steve1307's calculations, the 60-250 has a field of view like a 125mm lens at its minimum focus distance. In between infinity and MFD, FOV varies proportionately. The DA*300mm is also an IF lens, but focal length does not vary as much with focus, probably because it's a fixed focal length lens.
07-22-2012, 01:20 AM   #13
Finally did the test. Using catch in focus at minimum focal distance for both lenses. No cropping of course.
Absolutely no question you get *much* more magnification with the DA*300.
PENTAX K-5  Photo
PENTAX K-5  Photo
07-22-2012, 02:43 AM   #14
Thanks for the test Sandy. The magnification on the DA 300 is pretty useful.
07-22-2012, 02:51 AM   #15
Frogfish's Avatar
As Joe mentioned above - the DA*300 is the ultimate lens for Dragons & Damsels, Butterflies and insects of that size.
https://www.pentaxforums.com/forums/post-your-photos/179621-nature-clearwing-flight.html
https://www.pentaxforums.com/forums/post-your-photos/176694-macro-dragonflies...and-china.html
300mm, 60-250mm, da*, focus, k-mount, pentax lens, slr lens, vs
Pentax DA* 60-250mm @ 250mm vs DA 55-300mm @ 300mm resolution bwDraco Pentax SLR Lens Discussion 9 07-07-2012 05:16 PM
Tamron AF 18-250mm F/3.5-6.3 Di II LD is it really 250 in the long end nirVaan Pentax SLR Lens Discussion 12 08-15-2011 07:53 PM
People End of a long, hard day VikingDave Post Your Photos! 7 03-29-2010 12:32 PM
Pentax DA 55-300mm vs Tamron 70-300mm at long end (brickwall) tcdk Pentax SLR Lens Discussion 17 11-15-2009 12:52 AM
Need Advice on the Long end ...... daacon Pentax SLR Lens Discussion 12 09-06-2007 04:52 AM
All times are GMT -7. The time now is 01:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
