Originally posted by luftfluss Well, there's no UWA prime on the lens roadmap, so I wouldn't hold your breath.
on apsc 20 is not a UWA, heck it isn't even as wide as the very common 28mm in the 35mm format.
this is one of my big issues with apsc. On FF I could pick up literally hundreds of different 28 f2.8, but to achieve the same on apsc i would need to find an 18 2.0, heck i'd settle for a 20 2.0 but it would be huge and expensive compared to the same on FF
the big weakness of apsc is the wide to ultra wide range unfortunately
The DA15 is essentially covering of the 24mm range (not quite but close) but is also quite slow by comparison,
Edit I will pipe in that the Tokina/Lentar/???? 20 f3.8 in m42 is a nice sharp lens I picked mine up from a fellow forum member
