Originally posted by Digitalis I have seen enough shots from the 30mm f/1.4 to know it is has strengths, but corners sharpness isn't among them
It seems as though Sigma was on a mission to maximize center sharpness when they designed the 30mm 1.4. As a result, it's one of the sharpest lenses around at f/1.4. In fact, when Photozone tested the 30mm and the 31mm on the same body, the 30mm edged out the 31mm for center sharpness wide open. Pretty impressive considering that the Sigma was at f/1.4 while the Pentax was at f/1.8.
The fact that Sigma was able to accomplish this in a lens as inexpensive and as small as the 30mm 1.4 is even more impressive. The downside, of course, is that extreme border and corner performance suffers. But I think that Sigma knew that with how people would typically be using the 30mm, it would not be an issue for many users.
I myself haven't been bothered by the corners at all. But then again, I mostly shoot people, portraits, and events with my 30mm, and rarely use it for landscape or architecture. If I were shooting more in situations where edge-to-edge sharpness was vital, then I would own the 31mm. But for me, I value the larger aperture of the 30mm more than the corner advantage of the 31mm.
