08-16-2012, 09:05 PM   #91
Edgar_in_Indy's Avatar
My initial impression from the photo in the review is that the Sigma is significantly bigger than the Pentax, but it's actually the lens hood on the Sigma that makes it look so much larger. Is the hood on the 31mm tiny because it was designed as a wide-angle lens for full frame?
08-16-2012, 09:52 PM   #92
gtl
QuoteOriginally posted by Edgar_in_Indy Quote
I believe a bigger hood would lead to vignetting on the FA31mm on FF.
08-16-2012, 11:33 PM   #93
Banned
Niether lens is supposed to be a pancake lens (30mm f/1.4\FA31) and IMO it is a tad unfair to compare them to smaller, slower lenses - because I have yet to come across a pancake lens as fast as f/1.4. Fast lenses are always going to be big and heavy, when compared to slower lenses. Unless you are shooting Leica, or other mirrorless cameras for instance: The Voigtlander 35mm f/1.2 is one stop faster and slightly smaller than the FA31.
But manual focus, so no drive mechanism for the screw drive.
08-17-2012, 03:23 AM   #94
Digitalis's Avatar
QuoteOriginally posted by snake Quote
When you are using a lens designed for manual focus, it isn't as much of a hinderance when it comes to producing excellent work.
08-17-2012, 04:40 AM   #95
Banned
Never said it was. The quote I was citing was referencing size, not AF vs MF.. The drive mechanisms for AF, even screwdrive, require room, so it's tough to compare a lens for size, saying the aperture is larger, yet smaller than an AF lens with a smaller aperture.
Incidentally, one of my most-used lenses is an M85 F2.
08-17-2012, 06:05 AM   #96
Designosophy's Avatar
QuoteOriginally posted by gtl Quote
The odd thing about the hood on the 31 is I've seen it mounted on a Canon 5D, where it ends up rotated about 45 degrees. You would think that this would cause vignetting, but it doesn't. This tells me that the hood could have been bigger. I guess the designers didn't think it needed to be.
08-17-2012, 06:48 AM   #97
QuoteOriginally posted by Designosophy Quote
Yeah. I saw the images on Flicker from a guy with a Canon 5DII using a modified 31mm LTD. Because of the differences in mount, the lens is rotated 45 degrees clockwise (when looking at it from the front). I have been looking at ways to attache a larger hood for both protection and flare. There are a couple of good ideas out there for a slightly longer hood.
08-17-2012, 09:05 AM   #98
Hmm.... I dunno if this helps, but i kind of did a "rough" estimation on a rather simple concept, FL x1.5 crop factor = "proper" hood without vignetting.
I.e:
On FF - 28mm FL would require ~28mm/2.8cm deep for the hood before vignetting happens.
On APSC - 28mm FL would require ~42mm/4.2cm deep
How i knew, i've tested using a generic telephoto hood 40mm/4cm deep on my A28/2.8.
I've also tried, by stacking multiple generic 20mm/2cm deep "standard" hood making a 60mm/6cm deep hood, on my A50/1.4 without any vignetting.
Therefore, the FA31 would be able to use a ~46.5mm/4.6cm deep hood without vignetting. The original hood length helps but could potentially handle more with a longer one.
Take into consideration the DA*55, if i'm not wrong, take off its hood and shoot FF, and there'll be no vignetting but put it on and there will be vignetting. For this lens, it is all in the hood because 55mm x 1.5 = 82.5mm/8.2cm, therefore technically speaking, you can utilise an 80mm/8cm deep hood without vignetting on APSC. *Ok... NOT sexy.. But you get the idea... :P *
Another tip to note: Round down the final length after calculation for safety measures..
Go try..
PS: In the end, i just reverted back to a standard 20mm/2cm deep hood but a telephoto 40mm/4cm hood, on my A28 and A50 respectively, because it looks stupid and long... Hahaha!
08-17-2012, 09:22 AM   #99
Banned
Good thing Pentax has no FF
...yet.
k-mount, lens, pentax lens, photography, slr lens
Photozone re-reviews FA31mm hcc Pentax SLR Lens Discussion 91 05-30-2012 07:58 PM
Superceded siggy Full frame walk-about lenses? saladin Pentax SLR Lens Discussion 3 02-22-2012 01:28 PM
FA31mm LTD or DA 35mm LTD Macro pmastello Pentax SLR Lens Discussion 25 03-05-2011 08:54 AM
For Sale - Sold: FA31mm/1.8 Limited (Worldwide) LuzArt Sold Items 2 09-27-2010 12:20 PM
should I trade in DA*16-50mm for a FA31mm ltd? mokey Pentax SLR Lens Discussion 11 09-24-2010 01:27 PM
All times are GMT -7. The time now is 05:58 PM. | See also: NikonForums.com, part of our network of photo forums!
